Take a look and search for dry solder joints.
Best regards.
Best regards.
ecu on top of engine or the edu down the back? if no faults showing it might be injector seals
Spill valve working. (made activation with diagnostic, and shows that working ) and no errors.
does the glowplug lamp illuminate? is it injecting diesel if you crack off injector pipe?
hi, did you check the pins of your ecu?
I had the same, the pump valve is defected, the diesel was coming up to the ecu, and i look and looked than i saw a litlle drop on the pump . On the pump is an valve that leaks inside
ive seen this before but never found a reason either edu was fine but main ecm had a diesel smell to it
maybe ingress through wiring ?
but no apparent leaks from spill or inj?
maybe someones cracked inj at some point as this one i had did the rounds before i got it ?
but if you do find the cause give us a headsup mate
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
mite be injector pump got water in it i had that before
I had similar problem it was a dry joint on the fuel ecu bolted to the back of the engine, resoldered the joints and it worked fine.
Hi, dry joints is in pump ECU , but there I'm talking about engine ECU. Connector full of diesel and inside full of diesel. Before I has same problem, but found 2 parts blown, this dont have any visible damage, No any errors, in dash everything ok. Tomorrow will start with this car, so then could say more .....
Hi, after fixing engine ecu, I got error in pump ecu ( spill Valve)
Thanks to all for help.
Problem solved.
I could not fix the diesel pump error.
