How to install enigma 2 to ipbox 9000HD - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 79
  1. #31
    aftermath's Avatar
    Mar 2008
    you need to see this when its done
    -sh-3.00#
  2. #32
    Feb 2009
    Ok thanks I wait to see what happens I let you know in 30min later
  3. #33
    Feb 2009
    it still working !!! what should I do ?
    but I see is doing its job
  4. #34
    aftermath's Avatar
    Mar 2008
    follow from step 1 again, if it still happens, try a different usb stick.
  5. #35
    Feb 2009
    Hi , I tried and spend about 6 hours but no luck I'm tired of that I don't know what is wrong . Working with putty I don't get thoes masseges after "saveenv" ,
  6. #36
    aftermath's Avatar
    Mar 2008
    I dont either, but i get a few lines that show text after the saveenv part
    Its not easy to set up an E2 image if you have not used programmes like Katherein Control centre, Putty and FlashFXP.
    the guide in post number 1 is the easiest tut i have seen on any forum and believe me ive tried them all.
    Its worked every time for me no problem.
    so i can only suggest keep trying post 1 from the start and read it carefully,
    I have read many times that certain USB sticks can be the problem , ive known someone to have 2 usb sticks to work out of 6.
    my way i always do from now is.Only when i want to install E2
    1. Flash NLB image to HDD
    2. Flash Uboot 1.3.3 using PC editor.
    3. open the putty consol and copy and paste those 5 lines in 1 at a time and return.
    4. Partition and format your USB stick to linux ext2 or ext3.
    5. open Katherein Control Centre and hit the experts button
    6. wait till a box appears saying it has mounted your USB stick ( i do 2 partitions so have usb0 and usb1
    7. Open Flash FXP and ftp your image to mnt/usb/usb0 and rename it to enigma2.tar.gz
    8. Open putty again and telnet the commands inpost 1 to unpack the image to the USB stick.
    9. Press the relevent button on remote control to boot from Flash or USB stick
    this is my basic guise and post 1 goes into a bit more detail, only i do mine in a different order.
  7. #37
    Feb 2009
    Thanks for your information , I try again but let me ask you this any mess can happen to the image which is on the box now by trying to install enigma 2 on usb ? I mean this kind of installation doesn't do anything to main image on box? and also this version of enigma can run the box better than the other images ?
    when I want to install kcc it need net framework 2.0.5727 !!
  8. #38
    aftermath's Avatar
    Mar 2008
    Main image is safe mate.
    you cant do any harm to it.
  9. #39
    Feb 2009
    It doese not recognize "mv ./release/* ." command !!!!!
  10. #40
    Feb 2009
    I insatall e2 by flashing I really like it but I like to put on usb so I can play around it . I startesd again I just put nlb8873 but now kss can not go through Expert mode , it says "telnet login failed" but in test connection all are "ok" what do you think ?
  11. #41
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by arashkhaan View Post
    you dont need that command anymore.
    its time to test your stick now.
  12. #42
    Feb 2009
    Quote Originally Posted by aftermath View Post
    I did but no luck !! so I installed nlb image but as I said now kcc gives me error on "telnet login failed" what to do please help me out
  13. #43
    aftermath's Avatar
    Mar 2008
    is kcc telnet set to
    username = root
    password = relook
    or try putty to use telnet
  14. #44
    Feb 2009
    username = root
    password = relook
    yes it is root relook I need kcc for partition on usb !!
  15. #45
    aftermath's Avatar
    Mar 2008
    Try again with NLB image.
    did you enter the 5 lines into uboot 1.33 using putty and a serial cable ?
    also did you change those lines to your IPbox IP address, your Router IP address, and your PC address ?
