Hi, can I use multiboot img for booting Enigma2 from usb ? the new Enigma2 version does not need to set IP ?
I have a 16 Gb USb ,Then I Partioned it as Mentioned abOve tHen Using FTP I sended the file PKT_41 tar.gz to usb then using telnet i wrote the command cd /mnt/usb/usb0 then tar xzf PKT_41 tar.gz Then a comand comes that here is "no space left on device" Can i Know What Went Wrong?
Hi, just got my 900hd today and i only need it to do 2 things:
1. work as a positioner... because when i enter "positioner setup" on my sifteam image it crashes with a green screen and it restarts......
2. it must be able to use cccam as client and that i heard it's pretty easy with incubuscamd.
And of course a sort of "blue panel" would be really appreciated so i wanted to install PKT.
I was trying on sifteam but after inserting stick when i exec. mount no /dev/sdb comes up....
Now i see i must have DGS... is a NLB image ok? I'm not really good at this... so if i install nlb with the usb_update.img method this will work?
NLB images are sound mate, thats what i use also using E2, the NLB image has a blue panel as well.
Bro is using sifteam and E2 multi booting ,, and has no problems..
The green screen your getting could be a hardware issue, maybe the scart / hdmi settings not correct...
Hi i've just installed NLB image but it has no e2 actually.... it looks like the stb's original software :|
thats correct all standard images are more or less the same..
You will need to install E2 onto a usb stick so you can boot from different images.. There is a flash version of E2 available, but ive not seen it yet , just waiting to see what bugs it has first before i try it
e2 = enigma2, right?
I've had SIFTEAM and that had enigma2 but i had that problem couldn't use it to position my diseqc motor.
The display settings i checked them and they were correct, everything worked fine including FTA HD's just when i entered that "Positioner Setup" menu it crashed every time. I even tried with an older sifteam image.
Any ideeas on what I should do?
try flashing just the NLB image , 9341.
that should be fine... Forget Enigma 2 for now until we establish if your motor is working correctly.
Enigma 2 settings are a lot different for DiSEqC than a normal image..
I'm trying to get this usb boot working, but it have failed until now.
Here is the actual configuration of uboot:
U-Boot 1.3.1 (Jun 19 2009 - 17:18:38) - stm23-2008-03-19
Board: cuberevo (0x2D42C041)
Board: 12 dotmatrix vfd front
DRAM: 128 MB
Flash: 32 MB
In: serial
Out: serial
Err: serial
Reserve 0x2010000 bytes from 0xa5ff0000 for DGS upgrade buffer.
Setup mac address.
entering boot loader console.
cuberevo> setenv menu_1 'setenv ipaddr 192.168.0.20;setenv serverip 192.168.0.10
;setenv gateway 192.168.0.1;setenv netmask 255.255.255.0;setenv bootargs "consol
e=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/nfs nfsroot=/root/Desktop/ro
ot rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128
m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd
"nfs a5ff0000 192.168.0.10:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveen
v;boot'
cuberevo> setenv menu_2 'setenv ipaddr 192.168.0.20;setenv serverip 192.168.0.10
;setenv gateway 192.168.0.1;setenv netmask 255.255.255.0;setenv bootusb "run boo
bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 roo
t=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$net
mask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run
bootusb";saveenv;boot'
cuberevo> setenv menu_3 'setenv ipaddr 192.168.0.20;setenv serverip 192.168.0.10
targsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv
t=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$net
cuberevo> setenv menu_4 'setenv ipaddr 192.168.0.20;setenv serverip 192.168.0.10
e=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serveri
p:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
cuberevo> saveenv
Saving Environment to Flash...
Un-Protected 1 sectors
Erasing Flash...
Erased 1 sectors
Writing to Flash... done
Protected
After that the power switch is turned OFF/ON
and i press button 2 and hold it down for 5s.
Here is the communication from uboot:
DRAM: 128 MB
Flash: 32 MB
In: serial
Out: serial
Err: serial
Setup mac address.
Erasing Flash...
Erased 1 sectors
Protected 1 sectors
## Booting image at a0060000 ...
Image Name: Linux 2.6
Image Type: Blackfin Linux Kernel Image (gzip compressed)
Data Size: 1703603 Bytes = 1.6 MB
Load Address: 84401000
Entry Point: 84402000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Warning: Unable to determine if kernel is built for 29- or 32-bit mode!
Starting kernel console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 quiet - 0x00000000 - 0 ...
IP-Config: Incomplete network configuration information.
sda: assuming drive cache: write through
INIT: version 2.86 booting
Activating swap.
mount: you must specify the filesystem type
rm: unable to remove `/etc/nologin': Read-only file system
Checking all file systems...
fsck 1.39 (29-May-2006)
Hostname: (none).
INIT: Entering runlevel: 3
starting network.
error
info, udhcpc (v0.9.9-pre) started
debug, Sending discover...
debug, Sending select for 192.168.0.20...
info, Lease of 192.168.0.20 obtained, lease time 86400
route: SIOC[ADD|DEL]RT: No such process
adding dns 192.168.0.1
/etc/rc.d/rc3.d/S02anetwork: line 14: puts: command not found
Starting periodic command scheduler: cron.
rm: cannot remove `/var/etc/.box_crash': No such file or directory
starting vsftp daemon with /var/etc/vsftpd.conf
starting telnet
Why is the bootup seq saving env var?
Erasing Flash...
Following line indicates that internal flash is boot'ed (/dev/mdtblock3)
Shouldn't that line be exchanged to menu 2 (/dev/sda1)?
I have tryed 2 USB sticks formated in IPBOX and with the release_050_cuberevo.tar.gz unpacked. couldn't do the ./release/* . (no such dir, err )
Any ideas??
IPBOX is all the time booting to NLB-9580
btw, thansk for the very nice setup guide
Best regards,
read this thread and install the multibood file the same was as you flash your normal image. http://www.digital-kaos.co.uk/forums...ig-file-31708/
then try this way mate to set up your usb stick
Thansk mate,
Did the suggested procedure.
1. downloaded the usb_config_revo.img
2. Ipbox went into a repeated failed booting seq.
3. downloaded the usb_uboot_1.3.2_revo.img
4. downloaded the nlb9580_9000_b3.img
5. ipbox booted correctly
6. downloaded the usb_config_revo.img
7. downloaded the nlb9580_9000_b3.img
8. ipbox booted correctly
9. telnet to box
10. Used /mnt/usb , /mnt/usb/usb0 didn't exsist
Used /dev/sda, no harddisk installed
couldn't umount, device busy
1. Boot your DGS image, wait to full boot.
2. Insert your USB stick
3. Telnet to your box, execute mount
4. In the list check - if the /dev/sdb1 is mounted (if is FAT probably is mounted to /mnt/usb/usb0)
5. umount it - umount /mnt/usb/usb0
6. now execute fdisk /dev/sdb (not sdb1)
7. on the prompt press p - to see current partition table
8. press d - to delete partitions, if it is only one proceed, if not - press d again and delete all partitons
9. press p again - there will be no partitons now
10. Press n - to create new partition
11. select p - primary
12. select 1
13. press enter, enter
14. press w to write changes & exit
15. You have just created linux partition on your usb stick
16. Now format this partition - mkfs.ext3 /dev/sdb1
17. mount formatted partition again - mount -t ext3 /dev/sdb1 /mnt/usb/usb0
18. Now ftp e2 tar.gz to /mnt/usb/usb0
19. execute cd /mnt/usb/usb0
20. execute tar -zxvf e2image.tar.gz, wait few minutes to decompress all. (wait for prompt)
21. after decompress type, sync
11. rebooted with botton 5 pressed (USB, NO HDD)
12. IPBOX went in to cuberevo> (serial link)
13. wrote usbboot, failed no boot device.
14 tried button 2 same as button 5 ??
Is my box just a monday model? i find it a bit strange whats going on.
Thansk for the help mate, its appreciated
Best regards,
This is how I got my usb pen multi-booting with a lot of help from: bro satman aftermath & jamie-warez
Press menu> Plug-in> nlbpanel.plugin> USB Option> Format USB first then Mount USB
Telnet into box & you should see this:
inputCode:welcome to cuberevo cuberevo login: root Password: System bootup in progress - please wait [Disconnect bypassed -- root login allowed.] CubeRevo Custom release - No Limits Board --> http://www.nlb.to Release Edition - nlb9207 [NLB cuberevo /]$
Returns thisCode:mount
This is where I was having trouble my pen was on sda2 not sdb1Code:[NLB cuberevo /]$ mount rootfs on / type rootfs (rw) /dev/root on / type squashfs (ro) none on /dev type tmpfs (rw) /dev/mtdblock4 on /var type jffs2 (rw) none on /mnt type tmpfs (rw) none on /tmp type tmpfs (rw) none on /tmp/mqueue type mqueue (rw) proc on /proc type proc (rw) sysfs on /sys type sysfs (rw) devpts on /dev/pts type devpts (rw) tmpfs on /dev/shm type tmpfs (rw) /dev/sda2 on /mnt/usb/usb0 type ext3 (rw,data=ordered) [NLB cuberevo /]$
InputCode:/dev/sda2 on /mnt/usb/usb0 type ext3 (rw,data=ordered)So I had to change it to this sda not sdbCode:umount /mnt/usb/usb0
InputCode:fdisk /dev/sda
Should Returns thisCode:p
This shows there are 2 partions on the usb penCode:Disk /dev/sda: 1006 MB, 1006108672 bytes 255 heads, 63 sectors/track, 122 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 1 17 136521 82 Linux swap / Solaris /dev/sda2 18 122 843412+ 83 Linux
This deletes a partionCode:d
This deletes 1 partionCode:Partition number (1-4): 1
Returns thisCode:p
Code:Disk /dev/sda: 1006 MB, 1006108672 bytes 255 heads, 63 sectors/track, 122 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda2 18 122 843412+ 83 Linuxdeletes last partionCode:d
Returns thisCode:p
Which shows all partions deletedCode:Disk /dev/sda: 1006 MB, 1006108672 bytes 255 heads, 63 sectors/track, 122 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System
This creates a new partionCode:n
This selects it as the primary partionCode:p
Code:enterThese set the size of the partionCode:enter
This writes the data to the usb pen & returns thisCode:w
This is where i had trouble again look out for sda or sdbCode:The partition table has been altered! Calling ioctl() to re-read partition table. Syncing disks.
This writes the file system to the usb pen best advice is set it to ext2 not ext3 & Returns thisCode:mkfs.ext2 /dev/sda1
Code:mke2fs 1.38 (30-Jun-2005) Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) 122624 inodes, 244983 blocks 12249 blocks (5.00%) reserved for the super user First data block=0 8 block groups 32768 blocks per group, 32768 fragments per group 15328 inodes per group Superblock backups stored on blocks: 32768, 98304, 163840, 229376 Writing inode tables: done Writing superblocks and filesystem accounting information: done This filesystem will be automatically checked every 34 mounts or 180 days, whichever comes first. Use tune2fs -c or -i to override.This mounts the usb pen onto the boxCode:mount -t ext2 /dev/sda1 /mnt/usb/usb0
This changes the directory your working inCode:cd /mnt/usb/usb0
Now you should ftp the E2 image into mnt/usb/usb0
Back to telnet
This extracts the file & makes a image on the usb pen.Code:tar -zxvf e2image.tar.gz
It takes about 5 min at the end you should see something like this
With No errors wait till you see thisCode:usr/local/share/enigma2/radio.mvi var var/myepg var/myepg/opentv var/myepg/myepg_start.sh var/etc var/etc/.firstboot var/etc/rcS_user.sh var/etc/SIFTeam var/bin
Then inputCode:[NLB cuberevo usb0]$
wait 30 secsCode:sync
The reason mine was showing as sda not sdb is I didn't have a HDD fitted.
Remember to flash the multiboot config file into the nlb image
Thansk mate.
(Re)start USB...
USB: scanning bus for devices... 2 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
i'm currently booting Enigma2 SIFTEAM 050,
fixed_e2_050_pkt05a_ddtk40.tar.gz failed on first try.
Now the playing starts...
One thing that I found out is that uboot is running fdisk if it fails to see a /dev/sda2
is there a easier way to get this up running ?
