Page 1 of 6 123456 LastLast
Results 1 to 15 of 79
    V.I.P. Member sotiris70's Avatar
    Nov 2008
    Default How to install enigma 2 to ipbox 9000HD
    We will need the following:
    1) null modem cable
    2) a usb stick.
    I used this stick
    Kingston DataTraveler 1GB
    3)The programme PuTTy isi freeware and you will find it here:
    http://the.earth.li/~sgtatham/putty/latest/x86/putty-0.60-installer.exe
    4)The programme KCC for kathrein
    http://www.upload-drive.com/4117/KCC2_1b_rar
    5)The Enigma2_SifTeam_Cuberevo image for Ipbox 9000 HD
    Installation guide:
    1) We install uboot 1.3.1 and higher
    2) We turn off the ipbox 9000 from the on/off switch and we connect the null modem cable.
    3) We install the Putty programme and start the programme. Look at the bellow picture:
    4) We select serial,speed 115200 and at serial line we put the com we use. Then we push open.
    5) Then the bellow picture will appear at our PC.
    6) At the same time we switch on our Ipbox 9000, press ctrl + Z at our keyboard. Continue hitting ctrl + Z .
    If you did it right, then at putty?s window it will appear the following prompt:
    cuberevo>
    If not, switch off your receiver open again putty and do again 4), 5),6).
    7) At cuberevo> we copy paste the following (Don?t forget to customize the bellow settings to your network environment. ipaddr is the ip of your decoder, serverip is the ip of your nfs-server, gateway is your gateway ip, netmask is the mask of your home-net):
    setenv menu_1 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.6:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot'
    Push then enter and the cuberevo> prompt will appear again.
    Do the same also with:
    setenv menu_2 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_3 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_4 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
    saveenv
    8) When all is done well, at putty?s console we will get the message:
    U-Boot 1.3.1 (Jun 11 2008 - 15:53:39) - stm23-2008-03-19
    Board: cuberevo (0x2D42C041)
    Board: 12 dotmatrix vfd front
    DRAM: 128 MB
    Flash: 32 MB
    In: serial
    Out: serial
    Err: serial
    Reserve 0x2010000 bytes from 0xa5ff0000 for DGS upgrade buffer.
    Setup mac address.
    Saving Environment to Flash...
    Un-Protected 1 sectors
    Erasing Flash...
    Erased 1 sectors
    Writing to Flash... done
    Protected 1 sectors
    9) now you can restart your decoder and press the relative remote controller's button for 5 seconds to start the image you want:
    Press Button 1: start your image using nfs-server
    Press Button 2: start your image using usb pendrive if you don't have a SATA hdd
    Press Button 3: start your image using usb pendrive if you have a SATA hdd
    Press Button 4: start your original flash image in the decoder (DGStation's original firmwares and images based on them)
    10) We install KCC.
    Start KCC and set the following:
    Type your Ip adrress, username and password at the fields that been showed at above picture.
    Make a test Connection if all is OK.
    Then press at KCC toolbar the Experts button.
    Here we see our usb stick as sdb.
    Make right click at your mouse on usb?s /dev/sdb and the a menu window opens. We select new partitioner. We make 2 new partitions. The first one must be 512 mb at ext2 label and we name it XSYS1. The second partition will have the rest of usb size. Select ext2 label for it and name it XSYS2.
    Close KCC. Unplug the usb stick from receiver and place it again.
    11) Open a ftp programme. And copy paste the enigma2_cuberevo.tar.gz to
    /mnt/usb/usb0
    12) Open telnet and write:
    cd /mnt/usb/usb0
    tar xzf enigma2_cuberevo.tar.gz
    mv ./release/* .
    (At the second command, you will wait long)
    13) Switch OFF the receiver.
    Switch it On again and press the relative remote controller's button for 5 seconds to start the image you want:
    14) First time the booting for Enigma2 will take about 10 min.
  2. The Following User Says Thank You to sotiris70 For This Useful Post:
    Hayssam1 (3rd July, 2015)
  3. #2
    aftermath's Avatar
    Mar 2008
    A good thing about flashing this image is, when you have tried it, you just press the number 4 button for 5 secs when switching box on, and it boots your original image.
    It looks good, but it only allows scanning of hotbird at the mo... I think that when the official working version comes out, it will be the image to beat.
    P.S. the Splash screen is superb.
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    Quote Originally Posted by aftermath View Post
    Not entiry true my friend,,,, use latest openboxedit ( latest dreambox edit ) and send a decent satellites.xml to the box ( remember tell dbe your using new enigma2 settings ) and you can use any satellite.
    boom!
    Nov 2008
    Default E2 and IPBOX 9000HD & DVB-C
    Is this combination possible/available? If yes - where/when?
    Also i would like if there are keys available for the nlb
    Your support is warmly welcome
    THX
    NEWCOMER
    Jun 2008
    Never Never Land
    Quote Originally Posted by zoco View Post
    THX
    NEWCOMER
    Which combination?.... yes enigma2 is available, but not for a beginner user,, only supports 1 dvbs2 tuner,,, and no cable support yet.
    If you need uk keys for NLB,, ,, use any dreambox pack!!
    the keys are related to EMU,,, not the box itself.
    boom!
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by satman View Post
    I found an old dm600 image Satman and i took the satellite.xml file, used FlashFXP to ftp it to /var.tuxbox. It works a treat, but its seems to take a lot longet scanning than normal images do.
    Thanks M8
    Nov 2008
    Exclamation
    Good evening
    Mr. Sotiris70
    Possible to explain my pictures of me and I reached this stage and worked Stop
    Not absorb with great regret.
    Quote:
    /mnt/usb/usb0
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by madhbouh View Post
    Good evening
    Mr. Sotiris70
    Quote:
    /mnt/usb/usb0
    did you FTp to your box using a flash tool , like FlashFXR or Dreambox Control Centre. ?
    download the Enigma2 image , from the images section in here.
    Unzip it and copy the tar.gz file to the destination that Sotiris said. /mnt/usb/usb0
    it works if you put it in /mnt/usb folder as well, just remember when you telnet the box in number 12. change the cd /mnt/usb/usb0 to above. missing the /usb0
  10. #9
    Nov 2008
    Tomorrow we test
  11. #10
    Nov 2008
    Great i'm gonna test it asap!
    Thanx!
    Eekie
  12. #11
    Nov 2008
    Good evening.
    Possible help my problem.
    When trying to enter telenet comes this letter.
    Although I was many times
    relook and ipbox
    Download telnet(1) jpg free at Uploading.com
  13. #12
    Default guide
    Thank you for a good guide
  14. #13
    i have one problem with kcc
    when I do the test for connection it gives ok
    when I press expert it gives telnet failed
    how to solve this issue
  15. #14
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by john1 View Post
    did you format the usb stick to ext2 ( Linux ), and name the partition XSYS1. ?
  16. #15
    just tried to install the image but enigma2 doesn't boot. I used the CIe2T_ALL.tar.gz Image but this shouldn't be the problem
    i did everything like it was in the description and also get no error message. I updated the script with my ip-box adress (192.168.1.21) und pc-adress (192.168.1.36).
    here are the statements:
    setenv menu_1 'setenv ipaddr 192.168.1.21;setenv serverip 192.168.1.36;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.36:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot'
    setenv menu_2 'setenv ipaddr 192.168.1.21;setenv serverip 192.168.1.36;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_3 'setenv ipaddr 192.168.1.21;setenv serverip 192.168.1.36;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_4 'setenv ipaddr 192.168.1.21;setenv serverip 192.168.1.36;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
    saveenv
    with the KCC I created two partitions on my 4GB USB-Stick and extracted all files onto mnt/usb/usb0 and when I type ls in this directory I can see the extracted files.
    But when I restart my receiver I can press the Button "3" as long as I want but no enigma boots.
    What did I do wrong?
