lavman,
please attach photo of the component side, perhaps I can help you.
lavman,
Hi Mac Gyver, thanks for your help, have uploaded component side was just getting ready to have a bash at pulling apart so if you can save me some grief that would be great. I will hold off with both fingers and toes crossed.
Lavman,
I read and program making connections as the the photo.
if you have more doubts let me know.
ADEL.KSHLAF (2nd December, 2022), arti1 (4th November, 2014), cheero (22nd December, 2023), Donabe (6th September, 2019), DOUGLASMAITA (3rd February, 2017), dvbone (22nd July, 2014), dzamine670 (4th August, 2018), el genio (5th March, 2018), line44 (28th February, 2021), lordraidem (29th October, 2023), n599fbm (7th February, 2014), pablobonome (7th December, 2016), pierrepoulpe (27th February, 2018), shanektm450 (21st September, 2017), shtyrya2 (30th October, 2014), tamer1024 (10th August, 2018), willyboy28 (1st August, 2016)
Mac Gyver,
Ok thanks for that will give it a go..say what programmer are you using for this connection layout.
Lavman,
see my attachements here: http://www.digital-kaos.co.uk/forums...st10-f-115366/
dvbone (22nd July, 2014), rupertosur (26th December, 2013), ZYX (25th September, 2013)
Thanks again Mac Gyver you have been a great help I appreciate it.
hi
dear mac gyver,could u please send me winols?
there is a car that i just want to change its flash with other one and i do not want change eeprom because of immo.(in MM6PB).
which parts are related to immo and which parts are eeprom?
should i calculate cheksum?
hope help others.
auto coding,
see here winols:
http://www.digital-kaos.co.uk/forums...s-files-50034/
usually the immo is on bank 1 and bank 2 on ST10Fxxx flash memory, there are cases that are external serial EPROM memories
hi,thanks
could u explain me how can i calculate cheksum?
if i want to replace one st10f280 flash dump with other st10f280,i should just change 0,3,4,5,6,7,8,9,10 banks?
do i have a checksum problem if i do this?
auto Coding,
I never had any checksum problems in ECU reprogrammed.
when immo is in flash microcontroller always let banks 1 and 2, if the immo is an external eprom, change all the banks.
Hi friend:
Would you please tell me how to connect Xprog to ST10F280 on a IAW 4SF. I attach an image.
It is a Fiat Palio ECU.
Regards.
GJP.
pablobonome (3rd June, 2016)
gjpadron,
make connections as shown in photo
Carsoft2003 (8th July, 2013), maki (23rd April, 2016), n599fbm (7th February, 2014), shtyrya2 (5th May, 2014), tamer1024 (10th August, 2018)
MAc Gyver:
Thanks very much.
With kind regards,
GJP.
Dear Mac Gyver:
Thanks for the information above. Remember, I'm going to use the XPROG. So please, also indicates where are the points of the card in which I have TxD signals (N14), RxD (P15), RSTIN (A) and P0.4 (G15), to avoid having to unsolder the chip .
</SPAN></SPAN>
