gjpadron,
use an interface K line is much more practical, and to
you make no errors reading and reprogramming to 115200 bps.
Always I use the blue cable VAGCOM here.
gjpadron,
OK. Thanks very much.
I'm going to follow your instructions.
GJP.
I am searching ECU Marelli IAW 6LPB pin out. But i can not see any picture or document of all of you, maybe accout is not permited
Please help me!!
Dear all.
I have a same Marelli IAW 6LPB, SW16.908.024, SW9666133880. I am searching for this ECU pint out, 12V Battery terminal, GND and Diagnostic terminal.
Thank you so much
n599fbm (7th February, 2014), shanektm450 (21st September, 2017)
Dear MR. Mac Gyver
I wired for this ECU as your Picture, but It does not running, K-line Pin has 9.4 V but Scan tool can not connect to it. I think maybe there is no Ignition Pin. Can you help me
Dear MR. Mac Gyver
I try tool find this ING pin, and this is my result, I find it and my Scan tool can read information of this ECU
Thank you so much Mr. Mac Gyver
Dear All
I have an ECU of Ford Corp, part number is 8M51-12A650-ACB. Can you help me to find GND pin, B+ pin , ING pin and pins which is connect to OBDII DLC (K-line ...). I upload the picture of this ECU and connector
Thank you so much
thuanckd,
you are using these connections to scan the ecu?
these wires are for reading and writing the microcontroller st10fxxx line interface k .
Dear MAc Gyver
Yes, that is right, I use these connections to scan this ECU, I think the ECU of Ford corp. has a Kline interface, I just find GND pin, Bat 12V pin, i can not find ING pin and Kline diagnostic pin
thuanckd,
for scan is not necessary to put the ECU into bootmode
Hi Mac Gyver
I don't know what bootmode is. Could you tell me more about it please.
I has this ECU and I want to read data from it by Scan Tool. For my working, it need GND, BAT, ING and dianostic (Kline) pin.
THIS TES
HI FRIEND I HAVE FILE VINGIN PLEASE SEND ME THE PICTUERE ECU I AM NEW FOEM
