Please help me to read with xprog-M ECU IAW 6LP1.01.
Maybe someone have picture how to connect XPROG-M to this ECU?
Best Regards
Darek
Hello All,
Please see zip file. There is all info needed to read ST micro.
I comes a simple schematic to biuld interface and pin outs and connections along with ST software.
I have used it and it is a 100% working project (just make the right connctions).
Hope it helps.
Cheers.
"I find your lack of faith disturbing"
If you found my post useful, please use the "Thanks" and "Rep" buttons.
abdonete (30th August, 2015), ADEL.KSHLAF (27th April, 2023), Adi202 (9th July, 2019), albonidao (19th March, 2019), bresto100 (1st November, 2020), cheero (22nd December, 2023), eagleone-two (10th January, 2015), ecufix (9th July, 2014), elmaro (27th March, 2018), estwood68 (9th October, 2020), foxibg (4th December, 2016), gr_diver (26th October, 2019), jorgeluisd (5th September, 2016), lordraidem (29th October, 2023), magicworx (31st July, 2019), milerk (5th September, 2015), missfixit (28th February, 2015), nenadgorgi (23rd May, 2016), pablobonome (3rd June, 2016), pierrepoulpe (26th February, 2018), PierreTheron1 (16th July, 2016), raskolnikov1975 (21st February, 2019), scoot (18th January, 2018), Silver740 (1st August, 2019), speedy100 (5th February, 2015), willyboy28 (1st August, 2016)
hello all members i need pin out for edc16c3 307 peugeot
thank you
YOUR ECU IS 6LPC.105 IF NOT IT4S NOT FOR 207
Hello guys
Please i want to know if i can read my ECU Magneti Marelli IAW6LPA.02 with MPPS or not?
This is my ECU with ST10F280 processor:
And this is the list car of supported ECU of the MPPS:
Because i did not find a clear and definitive answer on the net
Thank you
yes, the MPPS read and write all ECU with MCU ST10Fxxx.
dzamine670 (4th August, 2018)
Thank you Mac Gyver, it is a very clear answer!!!
Mac Gyver please can you have a look here http://www.digital-kaos.co.uk/forums...-180hp-298724/ ?
It is a problem that i'm trying to solve since 6 months
i put some reply on your above thread.
place 2 560R resistors marked points on the board.
and see which of the pinouts is equal to your ecu.
ADEL.KSHLAF (29th November, 2022)
Thank you Zmann and Mac Gyver and all who are trying to help me but don't forget that i am a beginner in the world of the automotive elctronics so i'm trying to undersatnd and to learn.
Please Mac Gyver can you explain me what is the purpose of placing the two 560R resistors?To be able to read the ECU using the pinout that you showed me?
the purpose of these two resistors is enable levels high and low on the pins of mcu, to get in read or write mode.
I read and write with ST10FLASHER format .hex or MPPS format .bin.
with ST10FLASHER can read and write all the dump of MCU.
with MPPS can read and write only the injection map.
