thx for your work. hope blackbox 500s will boot.
//Edit:
Green LED is on, flashing the Bootloader with DOS & also Windows Version works. But I cannot flash the Box with Dreamup. It hangs at "upload completed, waiting for acknowledge". I try many differnet DreamUP versions. I also try many different bootloaders. Always the same. Green LED is on, Dreamup & patched Dreamups doesnt work.
But I get an Output on Serial Port after some time.
And I get this with similar Tool to DreamUp:Dreambox DM500
ENET: send frame error.
bootp packets sent = 5
BOOTP failed.
Network boot failed.
Unable to read configuration data
--- Device Configuration ---
Power-On Test Devices:
000 Enabled System Memory [RAM]
Boot Sources:
001 Enabled Application in Flash [FLASH]
002 Enabled Ethernet [ENET]
local=0.0.0.0 remote=255.255.255.255 hwaddr=00093401a43f
003 Disabled Serial Port 1 [S1]
Baud = 9600
Automatic Boot: Enabled
1 - Toggle Power-On Tests
2 - Change a Boot Device
3 - Change IP Addresses
4 - Ping test
5 - Change Baud Rate for S1 Boot
D - Display Configuration
0 - Exit Menu and Boot Application
The Flash is a TE28F640. I also tried other computers and RS323 Cables. Nothing works. Any ideas?Power ON DB Device [ESC to Abort]
HW ID: [000D447265616D626F782044004D3530300D]
Dreambox Detected...Ok!
Data1: [6C6F6164696E6720696E7374722E2066696C65]
Sending Flash Loader...
Data2: []
greetings
