Dont no how to jtag,,just dont no why Gemini image has timebomb
hi
can someone help me plz.
i would to connect my pcb jtag interface but there is not
HALT connector. how can i do plz.
tnanks to answer me
I have Echosmart 500s whitch is DM500s clone.i made jtag, all ok.I write witj jtagdos software, alps tuner, but it doesn't start.I have green led but with dremup i can't connect.i try all versions of dreamup.Can anybody hel me ? Thanks
Hi, my dm500 dead and jtag don't work!
Register test..... Check cable....
Run "flash help"
What means "flash help" ???
I've tried all suggestions but... died!
Hi all
Jtag appears ok . Tried using alp2.bat gets to erase flash and then stops at 0% forever !!
Also tried using other method jtag from dos window gets to write then window disappears.
Any ideas ?
Thanks in advance.
don't know why you ~~~~ all want to do a jetag job M8
if you do it properly dreamup work ok and it is very easy
you need a rs232 null cable and a old computer and will work
hi can i use serial port to jtag
hi everyone
i have a DM500
my jtag doesn't work, i don't know why
"ERROR : communication failed"
"ERROR : register failed"
i tried with a software find on google
what software should i use to repair my dreambox, to unbomb??
thanx
ps:my jtag cable is good
Hi all! my jtag doesn't work. "CPU and JTAG communication Check
ERROR: register test failed
Check your JTAG/LPT1 connection and/or adjust your voltage regulator"
I have a Dreamflesh for windows v0.1
I finished at this step
>jtagdm500 -m dm500 -i
Dreambox Dm500 board initialize
Flash info. : INTEL Unknown
[dm500] reading CA:00 ca 06 01 83
[CA] Ho Ho! CloneWARS corrupted b
Readed Config Area
Configuration Area
Mac Address: 00:09:34:aa:0b:cc
Redunderant Mac Address: aa:0b:cc
Tuner Type alps
DreamUP doesnt work
where can I get the Jtag Cable? in the video? where do you all people get your cable???
