Page 74 of 88 FirstFirst ... 2464697071727374757677787984 ... LastLast
Results 1,096 to 1,110 of 1306
  1. #1096
    Jan 2014
    hi,
    Please i need fujitsu mb91f script for upa-s (kia picanto 2016 dash)
    Best Regards
  2. #1097
    ivanrpm's Avatar
    costa rica
    Hi guys, I am searching the algorit for hyundai i10 2017, 24c16(its different from old models), I need it for make the script.
    I ran many calculators but I could not get the right one!
    MANY THANKS
    BEST REGARDS
  3. #1098
    reproteq's Avatar
    en algún lugar de España
    Hi , I am making a immo device script
    Wat is the best code for save read device to file.bin
    thanks in advance
  4. #1099
    reproteq's Avatar
    Quote Originally Posted by mexjack View Post
    I?m having troubles with SaveToFile(). It appears like unkonwn operator, any idea???
    hi , bro i am in same part.
    you solved?
    wat code use you ?
  5. #1100
    Default scripts write help
    hello
    i attach pajero scripts but when write km always o km , please help me
    in scripts how to program which one write & how to , hex or how
  6. #1101
    reproteq's Avatar
    4 Pascal Script Reference
    4.1 Device Management
    function AddAction( Caption, ProcName, DeviceName: string ): boolean
    function AddDevice( DeviceName, Description, GroupName, InheritedDeviceName: string ): boolean
    function AddDeviceGroup( GroupName, Description: string ): boolean
    function BlankCheckDevice: boolean
    function GetDevice( DeviceName: string; var DevBase: TDevice ): boolean
    procedure HideDeviceOrGroup( DeviceOrGroupName: string )
    function ProgramDevice: boolean
    function ReadDevice: boolean
    procedure ShowDeviceOrGroup( DeviceOrGroupName: string )
    function VerifyDevice: boolean
    4.1.1 AddAction
    4.1.2 AddDevice
    4.1.3 AddDeviceGroup
    4.1.4 BlankCheckDevice
    4.1.5 GetDevice
    4.1.6 HideDeviceOrGroup
    4.1.7 ProgramDevice
    4.1.8 ReadDevice
    4.1.9 ShowDeviceOrGroup
    4.1.10 VerifyDevice
    4.2 File I/O
    function AddOpenFileAction( Caption, DeviceName, FileName: string ): boolean
    function OpenFile( FileName: string ): boolean
    4.2.1 AddOpenFileAction
    4.2.2 OpenFile
    4.3 Hex Editor
    function GetByteHexEdit( Offset: integer ): byte
    function GetSizeHexEdit: integer
    procedure RefreshHexEdit
    function SelectAllMemoryRange: boolean
    function SelectEEPROMRange: boolean
    procedure SetByteHexEdit( Offset: integer; Value: byte )
    procedure SetProgramModifiedOnly( Value: boolean )
    function SetProgramRange( StartVal, EndVal: integer ): boolean
    4.3.1 GetByteHexEdit
    4.3.2 GetSizeHexEdit
    4.3.3 RefreshHexEdit
    4.3.4 SelectAllMemoryRange
    4.3.5 SelectEEPROMRange
    4.3.6 SetByteHexEdit
    4.3.7 SetProgramModifiedOnly
    4.3.8 SetProgramRange
    4.4 Message and Input Boxes
    procedure AddMsg( Text: string )
    procedure ClearMsgs
    function InBox( Caption, EditLabel: string; var Value: string ): boolean
    function MsgBox( Text, Caption: string; Flags: integer ): integer
    4.4.1 AddMsg
    4.4.2 ClearMsg
    procedure ClearMsgs;
    4.4.3 InBox
    Displays a prompt in a dialog box, waits for the user to input text or click a button, and
    returns the contents of the text box to Value parameter.
    Parameters
    Caption: string
    string that contains the input box title
    EditLabel: string
    string that contains the edit control label
    Value: string
    Return Value
    If the user clicks OK or presses ENTER, the InBox function returns True and Value
    parameter, whatever is in the text box. If the user clicks Cancel, the function returns False.
    4.4.4 MsgBox
    The MsgBox function creates, displays, and operates a message box
    Parameters
    Text: string
    string that contains the message to be displayed
    Caption: string
    string that contains the dialog box title
    Flags: integer
    Specifies the contents and behavior of the dialog box. This parameter can be a combination of
    flags from the following groups of flags. To indicate the buttons displayed in the message
    box, specify one of the following values.
    MB_OK
    The message box contains one push button: OK. This is the default.
    MB_OKCANCEL
    The message box contains two push buttons: OK and Cancel.
    MB_ABORTRETRYIGNORE
    The message box contains three push buttons: Abort, Retry, and Ignore.
    MB_YESNOCANCEL
    The message box contains three push buttons: Yes, No, and Cancel
    MB_YESNO
    The message box contains two push buttons: Yes and No.
    MB_RETRYCANCEL
    The message box contains two push buttons: Retry and Cancel.
    To display an icon in the message box, specify one of the following values.
    MB_ICONHAND
    A stop-sign icon appears in the message box.
    MB_ICONQUESTION
    A question-mark icon appears in the message box.
    MB_ICONEXCLAMATION
    An exclamation-point icon appears in the message box.
    MB_ICONASTERISK
    An icon consisting of a lowercase letter i in a circle appears in the message box.
    MB_ICONWARNING
    MB_ICONERROR
    MB_ICONINFORMATION
    MB_ICONSTOP
    Return Value
    If the function fails, the return value is zero.
    If the function succeeds, the return value is one of the following menu-item values.
    IDABORT Abort button was selected.
    IDCANCEL Cancel button was selected.
    IDIGNORE Ignore button was selected.
    IDNO No button was selected.
    IDOK OK button was selected.
    IDRETRY Retry button was selected.
    IDYES Yes button was selected.
    4.5 Miscellaneous
    Application: TApplication
    InputForm: TForm
    function IntToHex( Value: Integer; Digits: Integer ): string
    procedure SetProductInfo( ProductName, Description: string )
    4.5.1 Application
    4.5.2 InputForm
    InputForm: TForm
    4.5.3 IntToHex
    4.5.4 SetProductInfo
    4.6 RemObjects Pascal Script
    Types
    Reserved words
    Statements
    Library
    4.6.1 Library
    function FloatToStr( e: extended ): string
    function IntToStr( i: Longint ): string
    function StrToInt( s: string ): Longint
    function StrToIntDef( s: string; def: Longint ): Longint
    function Copy( s: string; ifrom, icount: Longint ): string
    function Pos( substr, s: string ): Longint
    procedure Delete( var s: string; ifrom, icount: Longint ): string
    procedure Insert( s: string; var s2: string; ipos: Longint ): string
    function GetArraylength( var v: array ): Integer
    procedure SetArrayLength( var v: array; i: Integer )
    function StrGet( S : String; I : Integer ) : Char
    function StrSet( c : Char; I : Integer; var s : String ) : Char
    function Uppercase( s : string ) : string
    function Lowercase( s : string ) : string
    function Trim( s : string ) : string
    function Length( s : String ) : Longint
    procedure SetLength( var S: String; L: Longint )
    function Sin( e : Extended ) : Extended
    function Cos( e : Extended ) : Extended
    function Sqrt( e : Extended ) : Extended
    function Round( e : Extended ) : Longint
    function Trunc( e : Extended ) : Longint
    function Int( e : Extended ) : Longint
    function Pi : Extended
    function Abs( e : Extended ) : Extended
    function StrToFloat( s: string ): Extended
    function FloatToStr( e : Extended ) : String
    function Padl( s : string; I : longInt ) : string
    function Padr( s : string; I : longInt ) : string
    function Padz( s : string; I : longInt ) : string
    function Replicate( c : char; I : longInt ) : string
    function StringOfChar( c : char; I : longInt ) : string
    4.6.2 Reserved words
    AND
    ARRAY
    AS
    BEGIN
    CASE
    CHR
    CLASS
    CONST
    CONSTRUCTOR
    DESTRUCTOR
    DIV
    DO
    DOWNTO
    ELSE
    END
    EXCEPT
    EXIT
    EXPORT
    EXTERNAL
    FINALLY
    FOR
    FORWARD
    FUNCTION
    GOTO
    IF
    IMPLEMENTATION
    IN
    INHERITED
    INTERFACE
    IS
    LABEL
    MOD
    NIL
    NOT
    OF
    OR
    ORD
    OUT
    OVERRIDE
    DEFAULT
    PRIVATE
    PROCEDURE
    PROGRAM
    PROPERTY
    PROTECTED
    PUBLIC
    PUBLISHED
    RECORD
    REPEAT
    SET
    SHL
    SHR
    THEN
    TO
    TRY
    TYPE
    UNIT
    UNTIL
    USES
    VAR
    VIRTUAL
    WHILE
    WITH
    XOR
    4.6.3 Statements
    begin statement1; ... statementN; end
    if expression then statement1 else statement2
    for counter := expression1 to|downto expression1 do statement
    case expression of caseList1: statement1; ... caseListn: statementN; end
    repeat statement until expression
    while expression do statement
    with object do statement
    uses
    try statement except|finally statement end
    exit
    continue
    break
    4.6.4 Types
    Byte, Shortint, Word, SmallInt, Cardinal, Longint, Integer
    Char
    String
    Real, Double, Single, Extended,Comp
    Boolean
    Array
    Record
    Variant
    Enumerations
    Classes
  7. The Following 2 Users Say Thank You to reproteq For This Useful Post:
    Anachem (17th July, 2019), maruti (30th January, 2019)
  8. #1102
    reproteq's Avatar
    hi
    is posible paste here a liltle script for save file when readDevice;
    Program Prog1;
    ///////////vars/////////////////////
    var code_1,code_2,code_3,code_4,code_5,DataArray,DataR eaded: string;
    spstr1,spstr2, offstr1, offstr2, offstr3, offstr4, offstr5,filepath: ansistring;
    ///////////////////////////// function ReadData //////////////////////////////
    Procedure ReadData;
    begin
    //////vars///////
    offstr1 := '0x53';
    offstr2 := '0x65';
    offstr3 := '0x67';
    offstr4 := '0x82';
    offstr5 := '0x96';
    filepath := 'C:\Users\w7\Desktop\ReadFile_dump.bin';
  9. The Following User Says Thank You to reproteq For This Useful Post:
  10. #1103
    hello
    thanks a lot bcoz i just try not much more pascal knowledge but try
  11. #1104
    hello
    dear very sorry but , u told me save like this scripts & paste read file
  12. #1105
    ivanrpm's Avatar
    costa rica
    Hi Maruti, here is your script working , now it writes!
  13. The Following 9 Users Say Thank You to ivanrpm For This Useful Post:
    Anachem (17th July, 2019), aqemqum10 (7th January, 2021), BBDOPAI (23rd January, 2022), Bens (15th February, 2021), eliet2000 (4th June, 2023), joejam (6th June, 2022), kidskung (23rd February, 2024), maruti (31st January, 2019), zar0079 (29th October, 2021)
  14. #1106
    HELLO
    Code_1:= inttohex(GetByteHexEdit($0A),2)+inttohex(GetByteHe xEdit($0B),2)+inttohex(GetByteHexEdit($08),2)+intt ohex(GetByteHexEdit($09),2);
    i change above bcoz hex swap
    now all okk km show ok
  15. #1107
    Oct 2018
    is the any one whose know how to connect an E8a of renesas to R5F3563EJFF MCU? I'm newbie here so I'm still coIMG20190131132418.jpgnfusing to connect it. I've try to connect some wire to pin oi mcu but there is not working.IMG20190131124747.jpg
  16. #1108
    HELLO
    /// ****************** Denso Code *************** //
    procedure NewKM;
    var
    n3,n2,new_KM: integer;
    n1,code,n4: String;
    /// *******CALCULATION ************** //
    new_km:= (strtoint(code)+1000000);
    n1 := '$' +inttostr(new_KM);
    n2 := strtoint(n1);
    n3 := $FFFFFFF - (n2);
    n4 := inttohex(n3,2);
    // ******* END of CALCULATION *********//
    this two stage how to sory for lots of question but i want to learn
    thanks for help
  17. #1109
    reproteq's Avatar
    Quote Originally Posted by reproteq View Post
    hi
    Program Prog1;
    Procedure ReadData;
    begin
    //////vars///////
    offstr1 := '0x53';
    offstr2 := '0x65';
    offstr3 := '0x67';
    offstr4 := '0x82';
    offstr5 := '0x96';
    i solved problem with this code .
    is maked from genuine upa v1.500r2
    /////////////////////////// FUNCTION ////////////////////////////////////
    procedure Button2Click(Sender: TObject);
    var he: TXHexEdit
    prHe: TXhexEdit;
    // AHexEdit: TXhexEdit;
    i, n: integert;
    b: byte;
    //////openfile
    begin
    he := GetHexEdit();
    if he <> nil then
    if OpenDialog1.Execute('') then
    he.OpenFile( OpenDialog1.FileName );
    Clearmsgs
    AddMsg('OPEN FILE OK!');
    /////load data hex to app
    prHe := GetHexEdit;
    if prHe <> nil then begin
    n := prHe.GetDataSize;
    XHexEdit1.SetDataSize( n );
    for i := 0 to n do begin
    b := prHe.GetByteData( i );
    XHexEdit1.SetByteData( i, b );
    end;
    XHexEdit1.DrawGrid;
    end;
    end;
  18. The Following User Says Thank You to reproteq For This Useful Post:
    maruti (2nd February, 2019)
  19. #1110
    reproteq's Avatar
    I am working in a full soft for upa
    here image of desktop
    when i finish i can share here.
    thanksAttachment 592508
  20. The Following User Says Thank You to reproteq For This Useful Post:
