There is something wrong in VIN reading. Doesn't have 16-th sign.
Can You change it?
Can You change it?
@newgeniehex all in connect upa press button ECU Infos.
Now the button set pin is online, only for you and your serial number.
Vin 17 is IO.
AMDOR (11th August, 2019), hbalazs (30th August, 2020), Jashmine1983 (6th December, 2014), pintobraz (29th July, 2014)
gameiruz (5th December, 2014), hbalazs (30th August, 2020), Jashmine1983 (6th December, 2014), mariusz971 (8th August, 2013), pintobraz (29th July, 2014)
hello everyone can somebody please shar script files for north american market please ' i can give my UPA serial NUmber if you like
thanks in advance
That is a script for old upa software, ver.1.1.
@ Nomis
Make it like this
procedure Denso_C46;
var
x,n1,n2,n3,n4,n5,n6,n7,Code
begin
Code := Edit1.text
clearmsgs;
SetProgramModifiedOnly( true );
case code of
'',null:
begin
ShowMessage( 'Enter Number in a Textbox');
exit;
end;
end;
n7 :=0
n1 := Inttostr(Round(strtoint(code)) +1000000);
n2 := n1[7];
n4 := Strtoint('$'+inttostr(int(round(strtoint(code))* 0.01))) xor $FFFF
if strtoint(n2) <5 then n3 := $F else n3 := $A;
n7 := (Strtoint('$'+n1[6]) xor 15) shl 4 xor n3;
n6 := $80 ; x := 0;
while x < $8 do begin
SetByteHexEdit( x,$FF);
x := X +1;
end;
n5 := strtoint(n2) mod 5 *2
x := 0;
while x < n5 do begin
SetByteHexEdit( x,N6);
x := X +2;
end;
x:= 8;
while x< 19 do begin
SetByteHexEdit( x, N7);
SetByteHexEdit( x+1,n4 or $0);
SetByteHexEdit( X+2,n4 shr 8);
x := X +4;
end;
RefreshHexEdit;
if MsgBox( 'Program Mileage?','Confirmation', MB_YESNO ) = IDYES then begin
ProgramDevice;
VerifyDevice
end ;
end;
You can still use old form of scripts if you don't know how to use the new IDE by clicking File-New-Script.
Thank you so much for your help . I think i need to know some very basic knowledge about pascal , how to work codes and functions .
Regards.
The Compiled *.Xscr script can easily change the name of the author so I think we need to protect it for bieng change by others who downloaded our works,
as for example I changed the name of Xzcr script (Simos71) by ZFKD (attached)
I also attached my sample script with my name, if anybody change my name in my works please try it. for most xscr script the name of the author can see if you open the xscr file in any hexeditor in ASCII
if anybody can change my name I will move to another protection
HI EVERYONE
I have created some scripts for my UPA programmer, but these scripts works with wathever UPA, maybe any one know how to programm in order to create a script which works only with my UPA (with my UPA serial).
THANK YOU SO MUCH
THANK YOU SO MUCH, I AM GOING TO TRY IT
EXCUSEME COULD YOU TELL ME HOW COULD I ENCRYPT MY SCRIPTS?? maybe with .udx??
