UPA USB sample script wanted - Page 73
Page 73 of 87 FirstFirst ... 2363686970717273747576777883 ... LastLast
Results 1,081 to 1,095 of 1305
  1. #1081
    May 2018
    scipts pack
  2. The Following 41 Users Say Thank You to greg198 For This Useful Post:
    AMDOR (11th August, 2019), Andresolivares (2nd January, 2019), autocargo (30th August, 2020), bubut (24th April, 2022), caprariu (11th February, 2023), davidjona (26th December, 2018), Diagnoauto (2nd May, 2020), Diogo Mello (31st August, 2018), eci (17th August, 2023), fuzz1 (9th June, 2021), hbalazs (30th August, 2020), hectorcairo (19th March, 2019), hmagga (12th December, 2019), hoangtu (20th September, 2018), hrmotorsport (1st June, 2018), ivica21 (29th January, 2023), Jarisko (30th October, 2022), just4upal (3rd February, 2020), kin51 (23rd May, 2019), majstorzare (24th August, 2022), menickb (3rd May, 2023), miloudmess (2nd February, 2019), mipmf (4th November, 2018), mkii (20th January, 2019), mossa19 (8th September, 2018), newgeniehex (13th April, 2022), PaoloDigital (2nd June, 2018), perucar (28th June, 2019), PowerCheck (6th October, 2019), prodlt (8th August, 2018), Pzolee (5th June, 2018), Recoder (18th August, 2018), saysso (14th September, 2018), skybroi (11th December, 2022), srht61 (2nd February, 2024), tanon (6th February, 2023), teuton (16th September, 2018), vomit (21st August, 2018), whim (17th January, 2019), wms (5th March, 2024)
  3. #1082
    Dec 2009
    Portugal
    hello,
    does anyone have script to upa-s to read corsa D bcm pin?
    best regards
  4. #1083
    Aug 2013
    Quote Originally Posted by mikroel View Post
    here is sample
    //Create Custom Device (Sub) Groups
    AddDeviceGroup( 'Samples', 'Select a Device' ); //create a root group
    AddDeviceGroupEx( 'Subgroup1', 'Select a Device', 'Samples' );
    AddDeviceGroupEx( 'Subgroup2', 'Select a Device', 'Samples' );
    AddDeviceGroupEx( 'Subgroup3', 'Select a Device', 'Samples' );
    Work in .uds or .xscr?
    I try make script load .Bin file in button but .xscr dont work
    Whow i make this?
  5. #1084
    Aug 2013
    I need to load an original .bin file in a button. which command do I add to the button to compile in .xscr?
  6. #1085
    Aug 2013
    Quote Originally Posted by hcip View Post
    The Compiled *.Xscr script can easily change the name of the author so I think we need to protect it for bieng change by others who downloaded our works,
    as for example I changed the name of Xzcr script (Simos71) by ZFKD (attached)
    I also attached my sample script with my name, if anybody change my name in my works please try it. for most xscr script the name of the author can see if you open the xscr file in any hexeditor in ASCII
    if anybody can change my name I will move to another protection
  7. #1086
    Aug 2013
    how edit .xscr?
  8. #1087
    Nov 2010
    someone has a script for Honda CRV 2016 eeprom 93C76 tssop8 ?
  9. #1088
    turbocip's Avatar
    Is there compatible scripts for upa UUSP - S ?
    thank you in advance
  10. #1089
    shuvarec's Avatar
    Aug 2018
    If somebody have script calculator to toyota sienna and can share ?
  11. #1090
    Jan 2010
    Russia
    Script for old VAG ECU's M3.X.X Bosch with EEprom 24C02 (B58258) Test and report!
  12. The Following 4 Users Say Thank You to Zaebasto For This Useful Post:
    Antonio266 (20th August, 2021), duckstar (5th May, 2020), hbalazs (30th August, 2020), zar0079 (29th October, 2021)
  13. #1091
    Nov 2018
    Myanmar
    I send to you private message about this, Please kindly reply me if it is possible. Thanks..
    you can make your own script than to ask members who have ready to use script,
    There is a lot of examples here, just an imagination and a simple calculation and you will be learn little by little, the others will not grab your knowledge from you
    as for example below, the instruction is for Toyota denso
    just to improve it and you can make it with your own
    /// ****************** Denso Code *************** //
    procedure NewKM;
    var
    n3,n2,new_KM: integer;
    n1,code,n4: String;
    begin
    SetProgramModifiedOnly( true );
    if InBox( 'Enter KM', 'New KM',code ) then begin
    if length( code ) >6 then begin
    if MsgBox( 'Out of Range', 'Error', MB_RETRYCANCEL ) = IDRETRY then begin
    NewKM;
    end;
    exit;
    end;
    /// *******CALCULATION ************** //
    new_km:= (strtoint(code)+1000000);
    n1 := '$' +inttostr(new_KM);
    n2 := strtoint(n1);
    n3 := $FFFFFFF - (n2);
    n4 := inttohex(n3,2);
    // ******* END of CALCULATION *********//
    //********* OFFSETS *********///
    SetByteHexEdit( $A,(strtoint ('$'+n4[2]+n4[3])));
    SetByteHexEdit( $9,(strtoint ('$'+n4[4]+n4[5])));
    SetByteHexEdit( $8,(strtoint ('$'+n4[6]+n4[7])));
    end;
  14. #1092
    Jan 2019
    india
    Default upa usb script wanted
    Quote Originally Posted by astrocar View Post
    hi
    Script of Renault Logan (Eeprom 93c56).
    bye.
    plz i want aal types of upa usb scripts
  15. #1093
    Jan 2019
    india
    i want hyundai odometer upa usb script
  16. #1094
    Jan 2019
    india
    upa usb full sript
  17. #1095
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    9 posts I want I want
