Page 1 of 15 12345611 ... LastLast
Results 1 to 15 of 212
    joe516's Avatar
    Mar 2008
    manchester
    Default sky box engineer tricks
    sky/sky+ box, use these tips to enter secret menu to reset/defrag
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
  2. The Following 11 Users Say Thank You to joe516 For This Useful Post:
    baadboy (17th August, 2013), jimmynewbie (25th April, 2014), Johnain (28th May, 2013), massey10 (19th April, 2015), mentalmagpie (6th June, 2013), mickymuller (9th June, 2014), MickyT999 (23rd February, 2015), Scotlandgh22 (2nd March, 2015), vinsim (12th July, 2015), white (19th January, 2016), yawsam (13th February, 2016)
  3. #2
    Nov 2008
    HOPES THIS HELPS
    DIY SKY PLUS REPAIR
    REMINDER - You are responsable for any repairs or actions taken to repair your SKY + equipment
    Stage One - "Full System Reset"
    1. Turn on your Sky + box
    2. Press the "Services" button on your Sky+ remote
    3. Select the option "System Setup"
    4. Access the hidden menu by pressing "0 then 1 then select" on your Sky+ Remote
    WARNING - The next Stage will result in you losing all previous recordings!!!
    5. Select "Full System Reset" - (Please ignore all other options under this menu)
    6. Allow the system some time to reset itself, and then it will turn off
    7. Turn on the Sky Plus Box
    8. Hopefully all recording problems are resolved - If not proceed to "Stage Two"
    Stage Two
    1. Remove Sky Plus Box "Mains Cable" - (either from wall socket or back of Sky + Box)
    2. Hold down the "Left and Right Arrow Buttons" on the front of the Sky + Box
    WARNING - The next stage will result in you losing all previous recordings!!!
    3. Reconnect the power
    4. Remain holding the "Left and Right Arrow Buttons" for around 30 seconds
    5. The "Green Sky + Ring", on the front of the Sky+ Box should now light up
    6. Release the "Left and Right Arrow Buttons"
    7. Press Select on the front of the sky + Box
    8. Now the System will "Format the Hard Drive" - The "Green Sky + Ring" will now spin backwards
    9. Allow the system upto 10 minutes, and then it will turn off
    10.Turn on the Sky Plus Box
    11.Hopefully all recording problems are resolved - If not proceed to "Stage Three"
    Stage Three
    2. Hold down the "Backup Button" on the front of the Sky + Box
    4. Remain holding the "Backup Button" for around 30 seconds
    5. The lights on the front of the Sky+ Box should now light up
    6. If your TV is connected to the Sky + Box, the following message will be displayed "Updating System Software"
    7. Release the "Backup Button"
    8. Allow the system upto 15 minutes, and then it will turn off
    9.Turn on the Sky Plus Box
    10.Hopefully all recording problems are resolved - If not you'll have to call Sky, and they'll promise to repair or replace it for ?65
    SPECIAL NOTE - If the following message is displayed - "Recording Interupted" - when recording or live pause is attempted:
    9 times out of 10 it means the "Sky viewing Card" IS paired with a Sky Plus Box - Just not the one your using!!!
  4. The Following 4 Users Say Thank You to Stripester For This Useful Post:
    baadboy (17th August, 2013), dragon123 (9th October, 2015), mickymuller (9th June, 2014), Nobster (16th April, 2016)
  5. #3
    Dec 2008
    worked perfectly! cheers! no ?65 fee this time and no replacement box.... again......
  6. #4
    Nov 2008
    [QUOTE=joe516;1759]sky/sky+ box, use these tips to enter secret menu to reset/defrag[/QUOTE
    i have a sky dish with no subscription, but i get all the teras tv and some other foreign channels, but my pictures on thef foreign channels seem to break up alot, whats wrong ??
  7. #5
    Dec 2008
    Default MANY THANKS
    hI I HAVE BEEN SEARCHING EVERY WERE FOR THIS TYPE ON INFO...
    NEADLESS TO SAY MY SKYBOX HAS JUST GONE DOWN,,,AFTER I REFUSED XTRA WARRENTY FROM SKYS TELEPHONE CALL!!! HMMM SMELL A PLOT .
    MANY THANKS
    ARC
  8. #6
    Jan 2009
    are you able to access more channels going into secret menu.
  9. #7
    May 2009
    Does this work the same with an HD box?
    ALSO
    Is there another option that just resets the menu so you don't lose all your recordings? - I think I saw the engineer do this before he did a full reset before
  10. #8
    DK Veteran terriers's Avatar
    Jan 2009
    North Notts
    Talking
    no u didnt m8....any reset scrubs the harddrive...and it works on hd or sd plus...the holding your fingers on left and right button while powering back up is also good for getting boxes out of stuck in standby too...
    As for the not losing your recordings,,the usb port on the box
    was gonna be for connecting a device to capture the recordings
    before doing a system reset,,or box swap,that way you could put the recordings back on box or new box and customer wouldnt lose their recordings....this is what they told us when i used to work for them 2years ago but still nothing yet...the amount of customers i got grief off was unbelievable,,yet understandable....
  11. #9
    Jan 2009
    North Notts
    Talking
    Anyone having problems with their remote be it sly or any other remote,,there is an easy way to check if its working....
    get your mobile phone and switch the camera on...next get your
    remote and put in front of camera lens,then press buttons on remote,and you can see it flashing if remote is working....
  12. #10
    Jun 2009
    can't wait to download
    sky always fool about
    would be nice to fix it myself for once
  13. #11
    DK Veteran gibbo74's Avatar
    Nov 2008
    leigh lancs
    great info ,
    i theres a guy on ebay selling all the sky engineer tips and tricks for ?2.99 , i bought it and its good but not has good has the info you can get for free from digital kaos
  14. #12
    Apr 2008
    hahaha this made me laugh, not for the post though...i went on a bskyb installation and health and safety course recently......and one of the questions was.... wat menu is accessed by pressing services ,system setup 0 ,1 select and one numpty put the secret menu ........
  15. #13
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    thats what i would put. I guess he failed?
    Read the Rules here; they apply to EveryOne.
    __________________________________________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 motor powered by UsalS
  16. #14
    Sep 2009
    Quote Originally Posted by joe516 View Post
    I need a reset for my ordinary sky digibox. Is there one?
  17. #15
    Default sky plus
    hey anybody got any info on how to fix a blurry screen on the amstrad drx 280 any help would be much appreciated cheers!
