CUMMINS ECM REPAIR TIPS - Page 2
Page 2 of 55 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 824
  1. #16
    DK Veteran hercamp's Avatar
    yeah the recalibration most correct the problem,because or maybe u dont have a physical component damage,also u can connect with calterm,upload the calibration,after that disconnect to ecm and open the cal file ,and select paramters search,edit the clutch switch and dissable,this component its optional ,not al models have it and u can dissable,its how I ve done couple times.
  2. #17
    DK Veteran mondao's Avatar
    ok I will try calterm
  3. #18
    Newbie imhsar's Avatar
    you can go for service center, where did u live, just tell me your location , i will give you the service center addresses, i think they will help you easily and you can further ask any other problems...
  4. #19
    yeah .we..go to the service center....and close the thread
  5. #20
    DK Veteran dimitar22's Avatar
    Jan 2009
    I don't think that going to the service center is the solution of the problem, the service center in my county is 200 km from where i leave, the point of this thread is to share solutions on how to to repair ecm by your self.
  6. #21
    sorry to say but I can not do good work with (calterm)
    maybe can give a different use for this (ECM) in another application,maybe generation,
    if anyone has an idea, (I have little imagination) sorry mates
  7. #22
    calterm ...at iquals to dct ...works in all cummins ecm?s and u can do anything...something special!!! u need to upload and change parameters after that download.
  8. #23
    thanks I continued trying to learn a little before sending a calibracion
  9. #24
    to download a calibration ...in a programed ecm its not so difficult just send...but for a new ecm or blank one u need to make bench cables.
  10. #25
    my problem is solved now, thanks I went with a cummins dealer and a new one is
    post closed
  11. #26
    Jan 2009
    Quote Originally Posted by hercamp View Post
    I have original 2 pin 3 pin cables can it be done with those one?
    Or i need some other cables?
  12. #27
    calterm...works with same connectors ... differences with insite ..its the bbot mode ...necesary in new ecms...and special for it are bench cables...the other funtions like read ,delete fauil codes,edit parameters and aply changes in the ecm ?s cal all possible with inline...in the 3x vercions I think its possible to with usb link,dpa4,noregon or rp1210a
  13. #28
    Top Poster peter21's Avatar
    San Miguel, SV
    hi guys i have a litle problem with ecm celect P/N 3618046, this ecm have the active code 351. Injector power supply below specifications inside ECM.
    This code to appear together with 434 code. i found problem in power supply to ecm. I repair it, and 434 code go to inactive but 351 still active...........Does someone know as repair this?
    thanks in advanced.
  14. #29
    makura's Avatar
    Quote Originally Posted by peter21 View Post
    thanks in advanced.
    HI
    Are you getting 100volts on the big green capacitor? If you check just behind your actuater harness you will see surface mounted transisters in between two heat sinks,they should be six in number,check that none of them have a shot circuit,if so replace and that fault code should be history.
  15. #30
    San Miguel, SV
    Quote Originally Posted by makura View Post
    HI
    hi makura thanks for answer. well i check the transisters and i found 2 bad, 1 between two heat sinks and 1 behind to the big green capacitor. I going tomorrow to buy them.
    thank you soo much for answer, i tell you how working the ecm.
