Page 53 of 55 FirstFirst ... 3434849505152535455 LastLast
Results 781 to 795 of 824
  1. #781
    Senior Member colh's Avatar
    Hi Donnie can you tell me what difference there is in ECM,s with same part no one off 12volt ISM to replace one on 24 volt ISX.Will 12 volt one work with 24volt or just get fried.Other prob is retrieving cal from the original ECU as it only hooks up every now and then and shows low voltage issues though all harnesses check OK.
    Regards Col
  2. #782
    I can confirm does work just went into features and parameters enabled battery voltage monitor on insite and switched from 12 to 24 after installing it and then reprogrammed it to ISX cal that was the same as in old ECM which I managed to open thru a second data connector[truck had a second 6 pin deutsch taped behind fuse panel as well as the 9 pin at front,havent seen that before].Old ECM kept coming up with 2 active faults low voltage at 2 sensors but were showing correct when tested and correct all the way back to ECM.Replacement ECM still isnt showing the faults so think its ok.
  3. The Following User Says Thank You to colh For This Useful Post:
    busha (23rd November, 2016)
  4. #783
    Jun 2016
    good day guys,i have two celect ecm i repair,following all the instruction i read in this thread,one is successfull and no problem
    but one only attemp to start when i push ignition,can somebody please guide me to the right direction..thank you.
  5. The Following User Says Thank You to otoy For This Useful Post:
    lush29 (30th November, 2016)
  6. #784
    Aug 2016
    good day everyone, i am having a problem with a celect plus ecm. voltage on the green cap is 12 volts and there is a clicking sound coming from the ecm. ecm lights on the dash sometimes come on sometimes they dont. pointers will be greatly appreciated.
  7. #785
    Jun 2016
    Quote Originally Posted by termmow View Post
    change all capacitors first..
  8. The Following User Says Thank You to otoy For This Useful Post:
    termmow (2nd December, 2016)
  9. #786
    Aug 2016
    changed all the caps including the big green one put it back on the truck working for now thanks thanks
  10. The Following 2 Users Say Thank You to termmow For This Useful Post:
    meroteki (14th August, 2017), otoy (4th December, 2016)
  11. #787
    Dec 2014
    Cerrar el interruptor y el calibre por Incal al cambiar su programaci?n EEPROM mejor con archivos flash y listo para un buen m?dulo si no tiene m?s defectos que 111. Si nesecita ayudar con el m?dulo de n14 privado Me gustar?a ayudar
  12. #788
    Roy Suryadwiananda's Avatar
    Indonesia
    Quote Originally Posted by david angarita View Post
    Please the English language so that the members immediately know what you mean, and can help you.
  13. #789
    Jun 2016
    good day guys,what calterm i use to download calibration to celect plus ecm?
    i use 3.6.4 but i cant communicate to j1708..i communicate to 3.2.0 but only
    upload calibration,no download.thanks in advance
  14. #790
    Oct 2016
    Does anyone have a list of the common components on a Cummins ECM?
    Example:
    Microprocessor
    EEPROM
    Logic Gates?
    analog-to-digital converters
  15. #791
    Jan 2017
    I have an 2150 isl ECM, it has a modified calibration (deleted egr, dpf & scr)
    what 's the best way to extract that calibration so that I can use it on other ECM's?
    thanks!
  16. #792
    Indonesia
    Quote Originally Posted by jo880111 View Post
    thanks!
    It seems you can not, if you want to use another calibration download from Cummins Incal,
    and directly overwrite it with a calibration you want.
    If that is you can do and succeed, please do share how / step steps here because I want to.
  17. #793
    DK Veteran hercamp's Avatar
    yes its possible to copy , from the first ecm , just you cant when someone encript the way to read flash , but need special software to protect .
    In my experience , you can use calterm ,you need special ecfg to read and write ....... not need open the ecm , or desold
    u can use galleto master , but need open , ktag and kess works to do that too but need boot mode .
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
  18. The Following User Says Thank You to hercamp For This Useful Post:
    Roy Suryadwiananda (30th March, 2017)
  19. #794
    Colombia
    Does anyone have the data sheet for this IC?, is a pre driver for a 3408501 ECM.
    Enviado desde mi SM-G920I mediante Tapatalk
  20. #795
    Indonesia
  21. The Following 2 Users Say Thank You to Roy Suryadwiananda For This Useful Post:
    DSAuto (12th September, 2018), Poptest (7th July, 2017)
