Page 12 of 55 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 824
  1. #166
    Member sptecnico82's Avatar
    Sep 2010
    Sonsonate, SV
    Talking
    Quote Originally Posted by makura View Post
    Copy cal files from your incal dvd to incal,read my post above.people if you take time to read other people's post's you would'nt be asking questions that have been answered already,and to make maters worse it's on the same page as your post.we are wasting time and space on the same issues here,PLEASE READ NEW POSTS AND USE SEARCH FACILITY HERE.
    Sorry, I have the calibration files, I dont have the configuration file...
    Share and use the THANKS button and from time to time somebody will help.
    PD. Use the REPUTATION button too.
  2. #167
    DK Veteran jctech's Avatar
    just beyond the edge of reason
    Quote Originally Posted by sptecnico82 View Post
    Calterm e2m and ecfg files are in the calterm thread
  3. #168
    Sep 2010
    Sonsonate, SV
    Im looking there right now.... do you have ecfg files for celect plus c94?
  4. #169
    Celect Plus uses e2m files, posted in the Calterm thread
  5. #170
    Dec 2010
    hello guis, sorry mondao for the late answer, the problem was ecm damage still need to cal the new ecm i recalibratethe egr valve like hercamp say and still same, i put other ecm and troble solve thanks to you and hercamp
  6. #171
    makura's Avatar
    Go to page 17 of the calterm thread you will get what you are looking for,and by the way celect plus uses E2M config files not ecfg.
    good luck
  7. #172
    I have an issue with a celect+ ecm i can here it ticking on when i open it but it has no communication with my adapter tried several times to rom boot it thinking that was the problem but no luck please if anyone can tell me where to check and what to replace??
    Thank you
  8. #173
    ok found theres no 5v on ecm where can i look first?
  9. #174
    makura's Avatar
    Quote Originally Posted by MoShCaKe View Post
    try turning key on for 3 seconds,then turn it off and try to connect to the ecm with the key off.
  10. #175
    Top Poster SaMirakle's Avatar
    Jan 2011
    That's going to be something internal then. I work on these ECMs everyday. I'm assuming the common 5V to all the sensor pins are missing or am I wrong? There are more than one pin that need 5V for the sensors.
    If it is something internal you will have to either replace the ECM or have it repaired (which I can do but I am located in the US. I don't know where you are located)
    ---:..Gratitude is the best attitude..:---
  11. #176
    Check all the fuses for your unswitched ECM power supply
  12. #177
    DK Veteran uzara's Avatar
    here in the world
    Please check the voltage regulator IC
    Input voltage and output voltage of the regulator
    regards
  13. #178
    Dec 2010
    hi can anyone help me with CENSE for QSK60G
    Found the module faulty and got a new one but it was not responding
    does it require any calibration or any other
    this is along with cm700 and ssm 558 on the engine harness
  14. #179
    Dec 2010
    Smile thankful to u if u can help
    Quote Originally Posted by hercamp View Post
    to download a calibration ...in a programed ecm its not so difficult just send...but for a new ecm or blank one u need to make bench cables.
    i am just searching for schematic of CENSE bench calibration for QSK60G and could not see ur post first unfortunate
    but in fact i would be more grateful if can send me diagram to make a bench calib cable for 3098771 on QSK60G or any suggestions to calibrate it
    ur early response to this is very much appreciable
  15. #180
    DK Veteran hercamp's Avatar
    dont need post that look in squematic and wiring cummins thread......enjoy
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
