Page 50 of 55 FirstFirst ... 404546474849505152535455 LastLast
Results 736 to 750 of 824
  1. #736
    Oct 2015
    Thanks for this useful info
  2. #737
    DK Veteran hercamp's Avatar
    Hi, i have an isb ecm, that seems all be ok , i mean no components blowed . But problem is positive to ground , and impossible energized .
    Can someone gimme advise ?
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
  3. #738
    Top Poster + donniemnemonic's Avatar
    Nov 2010
    Hell's garden of eden.
    Quote Originally Posted by hercamp View Post
    Hi Hercamp.
    Did you manage to win with this problem? haven't been on DK lately but would really like to help like you have always helped me in the past. Is this an ISBe ecm?
  4. #739
    Hey donnie , yes isbe. Cummins. Not solved, i had to replace the ecm, and try to find the problem in the old one.
  5. #740
    Nov 2010
    Hi Camp.
    Sorry for a late response. Hope I understand your post clearly but i once had an isbe ecm that failed and shorted between positive and negative and i resolved the issue by replacing the large surge protection diode inside the ecm. if that is your problem then just removing the diode will cause your ecm to work again but you will need to replace it for future protection of the ecm. hope this helps.
    regards
    Donniemnemonic
  6. The Following User Says Thank You to donniemnemonic For This Useful Post:
    Poptest (18th December, 2015)
  7. #741
    Thank you donnie
  8. #742
    DK Veteran Poptest's Avatar
    Sep 2010
    I have a 3619037 Celect ECM with fault 342. Engine does not start and it also does not communicate with Insite.
    Please advise me if there is a way to fix this.
    Thank you.
  9. #743
    Mar 2011
    celect plus ecm not reving up any solutions .
  10. #744
    May 2013
    Did you try to put the key switch on and accelerate full throttle three times before starting the engine?
    If so there could be an internal power supply failure, which could be lost of the 5volts to the accelerator pedal or there is no ground within the ECM to that circuit.
    hope this helps...
  11. #745
    May 2013
    All you need to do is to put it in )ROM BOOT MODE)
    Have your calibration cd and your insite ready for calibration and have an OEM harness connector with you (preferably a short harness connector with loose ends/wires)
    Put together these wires from your OEM harness pins 10+12 and 14 together then turn key on while holding these wires together in order for the ECM to swith into ROM Boot mode...
    after this process connect to Insite and calibrate the unit using that same part number. CAUTION: MAKE SURE YOU USE THE SAME PART NUMBER WHEN CALIBRATING EVEN IF IT FAILS TO CALIBRATE AND WHEN RESTARTING THE CALIBRATION...
    ITS WISE TO DO THIS PROCESS ON THE BENCH....
    Don't forget to thank.
  12. The Following User Says Thank You to Tuxie For This Useful Post:
    Wayne Techiemec (13th May, 2021)
  13. #746
    May 2013
    Those are for the injectors. usually they are blown by the faulty mosfets. they supply current to the mosfets and there is an overload to the resistors.
  14. #747
    Apr 2016
    Hi bud I have the same problem please let me kW if u find the problem but I have a feeling it's a soft ware problem cause if u leave the unite on for about five mins u can put the restore in while the unite is on n u will c it don't blow let's chat on email shaunchetty2510@gmail.com
  15. #748
    Mar 2016
    Hola amigos
    cualquier immo fuera, FORD F100 XLT 3.9 DIESEL
    ECU es CUMMINS MOTOR COMPANY
    P / N 4898112
    S / N 84165667
    E / C T90179.01
    SC 98463
    ESN 36187110
    MEMORIA 95640
    como hago para subir lectura de la memoria?
  16. #749
    Dec 2014
    Thumbs up Help
    Cummins N14 Celect ECM diagrama interno.pdf
    if you serve .. internal ECM nesecito diagram isx cm570 ... I have a problem with a module with code 124 always active (temperature Admission) and 213 (oil temperature) Could someone Past work (not for harness circuit problem. It is 100% internal circuit module someone could help me?
  17. The Following User Says Thank You to david angarita For This Useful Post:
    elbarto (24th May, 2017)
  18. #750
    Roy Suryadwiananda's Avatar
    Indonesia
    "with code 124 always active (temperature Admission)" >> right 124 fault code guys?
