yes i put other ECM and 0 codes of fault.....
"for a better world... where knowledge is shared"
: Trytofly:
AdrianCR (11th November, 2021), antelmo (25th October, 2016), bullseyemods (1st January, 2017)
This ecm failure position sensor 121 is ECM internal fault, I opened the ecm, but is not that part, it is failing, some diode, resistance, .... anyone know where the fault lies in the 121 ecm?
: Trytofly:
and also I have another faulty ecm 333, current to the injectors disconnected, is also ECM internal fault ... someone knows that part or component is failing within the ECM?
: Trytofly:
AdrianCR (26th April, 2021), antelmo (25th October, 2016), bullseyemods (1st January, 2017), busha (23rd November, 2016), DSAuto (14th January, 2020), jhon silva (9th October, 2016), leva (8th April, 2023), mathura (25th October, 2016), mmfix (4th October, 2023), mohamedkey (25th October, 2016), otoy (28th October, 2016), peter21 (25th May, 2018), Poptest (26th April, 2017), pppotamo (27th September, 2018), rdjorge (5th March, 2019), saican (15th June, 2017), sova (17th September, 2016), t01llam0k (25th November, 2016)
Hi!, i got a Celect with part number 3084473-rx, this have a TO-3 transistor in short between pins, the number of the transistor is MSC 9537 828S14, but i don't have find replacement device, can you help me?
Hello, I have a ECM Cummins ISX 3408501 damaged by fault code 343, ECM hardware internal error.Another ECM 3408501 by fault code 121: circuit crankshaft position sensor.
Any idea that has damaged ??
Hello friends, someone knows why this happens, change the eeprom xicor by a new record the data of the eprom disassembled from the ecu, and record in a new one, enter the mode romboot u happen what of the photo, some help please:
HELLO FRIEND DONNIE , I COME TO YOU THAT YOU CONTINUE TO STOP 94%
HELLO FRIEND, DONNIE, I COME TO YOU THAT YOU CONTINUE TO STOP 94%
Hi m8.
Trying physically rombooting ecm using romboot cable schematic found he on dk and try to recalibrate.
Donniemnemonic
