ESN 37187076 was built in 1999, with the now obsolete FCG (CM552) ECM (part number 3094141). It is a G2 engine.
The fuel pumps on these engines were Bosch RP39
ESN 37218459 was built in 2005, (760 HP @1800) with the GCS ECM 4067777. (1340 HP is 1000kW) It is a G1 engine.
The fuel pumps fitted to this engine are Bosch P7100, and are only be used with G1 and G2 engine ratings, higher ratings use P8500 fuel pumps with light load advance for white smoke control.
Try the G2 rating with CPL 2968, it is an EPA/CARB certified rating, and has the same number of flywheel ring gear teeth.
It is 1200 HP @1800
