Page 24 of 55 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 824
  1. #346
    DK Veteran jctech's Avatar
    just beyond the edge of reason
    Quote Originally Posted by makura View Post
    OK that explains it,when you have a foot print there are no parameters to copy.everything goes to 0 even your trip wil be reset just the same as an ecm in rom boot.
    That depends on what process was happening when the footprint occured, I have seen footprinted ECM that have all info available for restoring.
    A footprint occures when the ECM looses communication with the laptop/vehicle module during a write to the ECM, such Insite as erasing faults, changing parameters or a vehicle module restoring a parameter. Loss of communication can be caused by turning the key off, PC going into a power save setting, disconnecting a cable among other things.
    A footprint can also be caused by not waiting the correct length of time during the key off phase of restting faults and changing parameters and by turning the unswitched power off too soon after key off.
  2. #347
    jctech and makura, in this particular truck I can't get it to go for more RPM than 1400 in the first gears. I checked all parameters but maybe I'm missing one of them. The truck runs good but the driver is asking me for 1600 RPM. can you help me or tell me please which parameter I need to change to get more RPM in the engine?
    Thanks a lot
  3. #348
    Quote Originally Posted by jackalfa View Post
    Thanks a lot
    Look at the settings of "gear down protection" and "engine speed without VSS"
  4. #349
    Jul 2011
    I can not put unl CELECT rom boot mode.
    'Before it is necessary to establish communication with CALTERM?
    Can you do that with 9-pin connector?
    Help me please....
  5. #350
    Jul 2011
    I can not put a boot rom mode CELECT.
    to download the calibration fails
  6. #351
    Top Poster + donniemnemonic's Avatar
    Nov 2010
    Hell's garden of eden.
    Quote Originally Posted by eshis View Post
    Hi m8.
    Using the romboot cable try the following:
    Connect it up to the ecm and depress the switch on the romboot cable turn on your ignition supply, release the romboot switch then shortly after turn off the ignition supply. This will usually rom-boot your ecm if it fails try it a couple of times and eventually you will get it right. Hint: if you are able to here a clicking sound from your ecm with the key on then you should be able to hear it with the key off if rom-boot successful. Another way to do it would be to connect your ecm up to insite then start a calibration session when your ecm has gone say over 50 % -then disconnect from insite and your ecm will be in rom-boot mode.
    Another thing make sure that you are connected to your ecm on the sensor harness of your ecm using the rom-boot cable.
    Hope this answers your question and good luck.
    Donniemnemonic
  7. #352
    Top Poster + shisik's Avatar
    Sep 2011
    RUSSIA St. Petersburg
    plase hepl my
    please upload ecfg for this engine
  8. #353
    Default Celect Unknow Faults
    Please, Can I get your advice why this ECM is throwing this unknown foults?
    Thanks a lot members...best regards
  9. #354
    These are your unknown fault codes113 Engine Timing Actuator Circuit - Voltage Above Normal, or Shorted to High Source
    114 Engine Timing Actuator Circuit - Voltage Below Normal, or Shorted to Low Source
    125 Intake Manifold Pressure Low - Data Valid but Below Normal Operational Range - Moderately Severe Level
    135 Oil Pressure Sensor Circuit - Voltage Above Normal, or Shorted to High Source
    142 Oil Pressure High - Data Valid but Above Normal Operational Range - Moderately Severe Level
    152 Coolant Temperature Low - Data Valid but Below Normal Operational Range - Least Severe Level
    211 Barometric Pressure Sensor Circuit - Voltage Above Normal, or Shorted to High Source
    223 Oil Burn Valve Solenoid Circuit - Voltage Below Normal, or Shorted to Low Source
    225 Oil Replacement Valve Solenoid Circuit - Voltage Below Normal, or Shorted to Low Source
    421 Oil Temperature High - Data Valid but Above Normal Operational Range - Moderately Severe Level
    435 Oil Pressure Sensor Circuit - Data Erratic, Intermittent, or Incorrect
    443 Accelerator Pedal or Lever Position Sensor Supply Voltage Circuit - Voltage Below Normal, or Shorted to Low Source
    445 OEM Switch Supply Voltage Circuit - Voltage Above Normal, or Shorted to High Source
    I think the calibration has somehow become corrupted, try to recalibrate the ECM using Insite, with the standard calibration from the InCal disk.
  10. #355
    Post a screenshot of the ECM audit trail.
  11. #356
    Thanks jctech, I'm not in the truck yard but I will try to return so you can help me, thanks again. I already recalibrate the ECM with Insite, I thought too, that maybe the info in the ECM become corrupted but it has the same parameters as when I checked it the first time. The driver told me that everything was fine until the starter started to give him problems then he had to fix the alternator and when the electric man fixed the alternator, the check engine started to flash.
    There is the possibility that the ECM is now faulty because the voltage changing in the truck alternator?
    thanks again...
  12. #357
    Oct 2010
    thanks again...
    Before you replace the ECM, try removing the alternator belt, clear all of the codes and test run the truck with the belt off. Electrical noise in the system from a defect in the alternator could be the cause. Also, check the timing sensor as a possible source of electrical interference. We had a Celect Plus logging strange codes and found the culprit to be the timing sensor, when removed we found it was cracked and had a small chunk out of the end of it (?). Also check all of the ECM ground and power connections.
  13. #358
    Jul 2011
    I can not even calibrate the CELECT ..
    If someone please help me speak Spanish.
    this is my mail: ( no addys )
  14. #359
    Nov 2010
    Hi m8
    Have had a similar experience with several celect ecms in the past and have managed to repair by recalibration as jctech has mentioned. Check also if fault code 434 is active. If so after you connect to insite turn your ignition key off and on and check if the 434 fault becomes inactive. If not then it is highly possible that your ecm is faulty and will need to be repaired.
    Hope this helps.
    Donniemnemonic.
  15. #360
    Nov 2010
    Hi m8.
    What exactly are you failing to do? If you are trying to calibrate using calterm maybe try using insite, it is a lot easier than calterm. What is the state of this ecm you are trying to recalibrate. We need more info so as to assist you. Did you try any of thje stuff i mentioned in an earlier post on this page?
    Donniemnemonic.
