Page 36 of 38 FirstFirst ... 263132333435363738 LastLast
Results 526 to 540 of 569
  1. #526
    Hello
    I install camera rear with multimedia interface in benz 211 year 2004 with comand ntg1/2, this interface video is conected to comand with cable most and with green fakra conector.
    I select video and i can see rear camera, but if possible activation camera when i select rear gear in gear box, and that don need pust bottom video,
    Exist some form with developer mode ? i have star diagnose
    Thank for your response
  2. #527
    DK Veteran Mackhack's Avatar
    Unfortunately NTG1 was never intented to have a backup camera connected and therefore there is no way to make it automatically switch to the camera view.
    I retrofitted a MB TV tuner to my car and connected my backup camera to Aux1 or 2 of the TV tuner and power for the camera comes from the reverse light. All I do is press the Video button /Aux1 and I get the camera view. Sorry that I don't have a better answer for you. If you want it automated you will need to swap your COMAND NTG1 with an NTG2.5! That can be version coded to how you want it to work.
  3. The Following User Says Thank You to Mackhack For This Useful Post:
    MV auto (27th March, 2015)
  4. #528
    Feb 2011
    60N 25E
    Sprinter 906 add tempomat/cruise contorl need code to
    CDI -> Development data -> variant coding select dorpmenu code seim codingin (text) what is now + tempomat,
    ESP -> development data -> variant coding select dropmenu code seim coding (text) what is now
    change aus to ein
    only cdi and esp need coding
  5. The Following 4 Users Say Thank You to MBFIX For This Useful Post:
    Col19 (13th November, 2019), coolis (24th March, 2015), MV auto (27th March, 2015), violator11 (11th November, 2016)
  6. #529
    Feb 2011
    60N 25E
    How to Lower Airmatic (SLF) no voltage limit.
    Airmatic -> actuations move toward calibrated level automatic -> F3
    then go development data -> actuations -> complet index of actuations -> drehwinkel o***etwerte schreiben -> F3 ->
    put box how meny mm want lower(exsampel val -20 var -20 ha -15) pres F3
    some time need pres SG Reset (scrol down found seim actuations complet index of actuations menu)
  7. The Following 5 Users Say Thank You to MBFIX For This Useful Post:
    Col19 (13th November, 2019), coolis (27th March, 2015), MV auto (27th March, 2015), will4u69 (14th May, 2015), yceo4u (21st June, 2016)
  8. #530
    Fec001's Avatar
    Hi!
    Is it possible to deactivate seat belt warning on CLS W219 MY 2008????
  9. #531
    Yes it is!!!
  10. #532
    Apr 2009
    W639 F64
    Auto folding mirrors nice to see coding for this!
    thxs
    I have now succeeded in doing this in DAS
    quite easy really using a translator!
  11. #533
    Feb 2013
    can't get proper development data on w211 sbc, used it before on other w211 sbc - all was good license is not out of date, getting confirmation when starting DAS in german language "Developer kit...".
    when selecting sbc>development data> control unit adaptations>control unit adaptations (download)> shadow memory only this
    why there is no option control unit adaptations (variant coding)????
    tryed other keygen, the same getting in german "Developer kit" confirmation, development data works good for airbag but not SBC.
    Help, customer came back second time already
    Xentry 09_2014
    SBC part num A0054319612
  12. #534
    Quote Originally Posted by kvadratas View Post
    Xentry 09_2014
    SBC 1.2 doesn't have that option to select in DAS. Only 1.0 Und 1.1.
  13. The Following User Says Thank You to Mackhack For This Useful Post:
    kvadratas (31st July, 2015)
  14. #535
    Feb 2013
    How to know which is SBC1.0 or 1.2?
    by data version or by year?
    this particular sbc unit:
    hw status 33/05
    sw status 48/05
    data of manufacture 02.06.08
    version (internal) DK0010
    diagnostic data version (SGML) 5.1.20
    strange data of manufacture if we would compare hw status date....
  15. #536
    hw status 33/05
    sw status 48/05
    Can't remember but I think under version.
  16. #537
    hello
    do you have the procedure forcalivrating ABC system please with developper
  17. #538
    Bosna
    Hi members. How to enable passenger seat belt warning on mercedes w211-year 2005. I tried many option in dev. mode on instrument cluster and AB module without success.
    wbr
  18. #539
    workshop
    only IC,easy after coding reset
  19. #540
    Quote Originally Posted by euror View Post
    211 589 04 21 00
    211 589 0421 03
    211 589 0421 05
    Bought a set years ago and was ?1500!!
    Where this tool to buy, online cannot find/?
    Is it worth having this due to that price?
    Even pm for places from serious members.
