This started as a sugestion
In here i will post my allready published developer tricks that are circulating around Dk
From time to time i will add some new tricks as well
Hope this will encourage others as well
Last edited by Qrius; 30th April, 2011 at 08:10 AM. Reason: Removed a seller's name
al70 (27th July, 2022), alberto3a (2nd April, 2021), Col19 (13th November, 2019), diac (12th April, 2014), dzmitry (10th July, 2019), Eltarmo (18th March, 2021), gomarota (21st May, 2013), Hayssam1 (26th June, 2014), latino (19th June, 2013), MOBILTRONIC (5th January, 2022), mohamedkey (27th March, 2014), plore90 (28th November, 2016), sebastian (15th November, 2014), stanislav georgiev (26th June, 2015), stefaudio (21st September, 2014), test-mate (19th May, 2013), trafas (3rd March, 2016)
Here is how to do it,
In Developer mode :
Kombiinstrument -> Diagnose nach Werkangabe -> Steuergerate-Anpassungen ->
Steuergerate-Anpassungen (Variantencoderierung) -> Variantkodierung Werkeinstellungen ->
In the menu that shows , you scroll down untill you read the line : Tankinfo im Reichweitebild
enable this option
now you have tankinfo in the screen that otherwise only showed range
If you allso wanna adjust the way fuel consumtion is showed
you scroll a little more down untill you read the line : Verbrauchanzeige km
you can change it from L/100km into km/l
Scroll down and confirm Coding by pressingF3
if you watch your Instrument Cluster , you notice that scrolling through the menu , nothing changed .
For this , the "Kombiinstrument" needs a reboot.
to do this in Developer mode we go back by hitting F1 -> 3 times
then choose Ansteuerungen -> Gesamstliste aller Ansteuerungen ->
Scroll down untill you see the line : Steuergeraet Resetten (PowerON-Modus) (FN_Reset_SG_Power_ON)
Press F3 and confirm again with F3
Now you will see the "Kombiinstrument" reboots
If you think this would help you
Please dot not forget to click THANKS
alberto3a (2nd April, 2021), Col19 (13th November, 2019), Deekushman (28th July, 2018), discouver (22nd September, 2016), gogoli (6th February, 2014), Grover2000 (27th September, 2013), Hayssam1 (4th May, 2017), JAYAUTO (30th September, 2013), kim sun sung (14th March, 2014), kina (4th April, 2020), kiwi1hu (8th April, 2013), latino (19th June, 2013), mende (17th November, 2015), mohamedkey (27th March, 2014), ph0en1x (11th December, 2013), plore90 (6th July, 2018), rabihfiras (10th June, 2019), raffaell0 (28th November, 2015), sebastian (3rd April, 2013), ssaliaj (14th October, 2016), Styffen (9th February, 2017), ToneZ (8th October, 2013), toutougsmserver (16th December, 2018), viviserifu (3rd November, 2019), Zohar (26th August, 2013)
Here is how to : clean ASSYST Plus Memory
All we need is DAS in Developer mode
In Developer mode : (tested version 07-2009)
Steuergerate (Control units) ->F3
Aufbau (Body) ->F3
ZGW (CGW) ->F3
Entwicklungen (Development data) ->F3
Steuergerate - Anpassungen (Control unit adaption) ->F3
Programmieren (Update) von Steuergeraten (Control module programming) ->F3
Steuergerat programmieren (Auswahl) (Program control unit (Selection)) ->F3
Now we have 2 options to flash the ZGW/CGW with, choose the correct one
Don't panic ! if you choose the wrong file , it terminates process and you can do it over again
Confirm Flash pop-up with Ja (Yes)
After that it says : "Das Steuergerate wurde erfolgreich programmiert"
-> "OK" it ask for a reset -> JA (Yes) ->
ECU Reset (FN_ECU_Reset) ->F3 again ->F3
Now you Completed full History wipe out
Everything discussed in this post is for experimental and educational purposes only
111arm (30th October, 2019), blueabyss (4th May, 2013), Col19 (13th November, 2019), danielboom00 (23rd April, 2015), esse (2nd April, 2019), gogoli (6th February, 2014), ION CRISTI (17th February, 2016), jackeldestripador (27th November, 2018), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), latino (19th June, 2013), mende (17th November, 2015), pbn (3rd February, 2016), ph0en1x (11th December, 2013), plore90 (20th May, 2019), raffaell0 (28th November, 2015), sebastian (3rd April, 2013), trafas (3rd March, 2016)
Make sure engine is running !!!
In Developer mode you need to go to Entwickelingsdaten - > ansteueringen -> Gesamstliste aller Ansteuerungen
to see how many times brake has been pressed there is a line that says: Bremsenzahler (DJ_GetBrLive)
then 1 line down there you see Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen -> click it !
Parameter uINBR = 0
then click F3
1 line down Bremsenzahler auf beliebigen Wert setzen (DJ_SetNBr) -> click it
Parameter uINBR = 0
then click F3
then scroll down untill you see the line's :
Lebensdauerzahler F neu berechenen (DJ_CalcLiveTime)
Parameter uINBR = 0
then click F3
Lebensdauerzahler F neu berechenen und schreiben (DJ_BuildAndWriteF)
Parameter uINBR = 0
then click F3
Log out of SBC !!
log out of verhicle !!
let engine run at least 10 minutes or drive at least 10 minutes
If no coils are damaged , SBC fault code is not AKTUEL nomore
111arm (30th October, 2019), Col19 (13th November, 2019), Deekushman (28th July, 2018), diac (12th April, 2014), dritan (21st January, 2017), esse (2nd April, 2019), Fec001 (19th September, 2013), foxibg (28th March, 2017), jackeldestripador (26th November, 2018), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), lexa-dok (25th April, 2013), mende (17th November, 2015), micmax4 (4th December, 2013), minchion (28th September, 2013), nick_f (9th September, 2015), raffaell0 (28th November, 2015), sabe (25th June, 2014), sazimam11 (7th October, 2017), sebastian (3rd April, 2013), Tadas chipDPF (29th October, 2015), tor2lehel (25th October, 2013), trafas (3rd March, 2016), treo (25th April, 2013), TULGEYWOODMAN (26th September, 2013), vageric (27th September, 2013), Zohar (26th August, 2013)
In Developer mode :
Audio, Video, Navigation und Telematik ->F3
a screen might pop up with all kind of settings, ignore and press F2
New screen with ESD warning ->F3 COMAND /AUDIO -AUDIO 50 oder COMAND ->F3
Entwicklungsdaten ->F3
Steuergerate-Anpassungen ->F3 Steuergerate-Anpassungen (Variantencoderierung) ->F3
HU Parameter ->F3 scroll down to line: Driving speed is more than 0 kph and
Driving speed is more than 10 kph and BOTH enable them and ->F3 to confirm coding
Now you be able to watch DVD/TV when car is in motion
This procedure won't work for W204 W221 and newer models
111arm (30th October, 2019), 219buster (17th October, 2013), Col19 (13th November, 2019), F0RM (29th April, 2013), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), latino (19th June, 2013), mende (17th November, 2015), mohamedkey (27th March, 2014), poker (21st August, 2015), raffaell0 (28th November, 2015), sebastian (3rd April, 2013), Tadas chipDPF (29th October, 2015), trafas (3rd March, 2016), Zohar (26th August, 2013)
Nicely done - Very nicely done.
Our sincere Thanks to Qrius for all the time and effort he continuously injects to the Forum. His contribution to the success of DK is invaluable.
G.
HI mr Qrius
Would you help me in this matter?
http://www.digital-kaos.co.uk/forums...2/#post1050667
Thank you
Hi mr. Qrius
With a lot respect of your knowledge, would you let me know how to escape dtc C235C from SBC W211?
http://www.digital-kaos.co.uk/forums...ervice-230528/
Thank you
Col19 (13th November, 2019), gigimercedes (2nd November, 2017), mendox (22nd July, 2014)
Please help stamp out this disgusting trade.
JUST SIGN THE PETITION .....PLEASE
https://savedogs.soidog.org
Sprinter W906 2006 CDI4. I'm trying to activate the cruise. In the ESP block, I changed the setting. In the CDI4 block in variant encoding, I see the setting of NSG_TEMPOMAT. Do I understand correctly that the cruise in the CDI4 block has already been included?
If the menu you get does not have this Tankinfo im Reichweitebild line, search for the line Bild Reichweite ohne Tankinfo and disable it. Then, look for the line Bild Reichweite und Tankinfo and enable it.
These procedures should work on all w203, either one way or the other.
Regards
my m8's got xentry das running on his ibm laptop and i'ts in English why then do we have german in the forum? the only time German language really comes up is when you just start
the program after that everything's in english language he's doing master resets and all sorts it's working exceptional because i've seen it in action my only regret is that i still cant get the star multiplexer interface and leads at a reasonable price can any one help in pointing me in the right direction?
