Page 2 of 38 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 569
  1. #16
    DK Veteran gmatj's Avatar
    Dec 2009
    Heaven (is place on earth)
    Quote Originally Posted by rjm3 View Post
    question from a newbie ...
    what is DAS and where can i get it ? do i need any other hardware ?
    I am mainly interested in activating tv in motion
    Thanks.
    DAS is an overkill, and a very expensive solution for you m8 if the only think you want to do is activating tv in motion .
    If you read a little bit in the forum you will find all detailed information of what DAS is , and how to go on about it.
    Maybe get a TV activator ??
  2. #17
    Apr 2010
    Hello everyone, thank you for this information.
    I am still trying to find out how to view the crash record for cars that have been in accidents.
    I am told its in the AB module, and you can read which airbags were deployed and what speed/time/date it has occured.
    Can someone provide us with the steps to view this data?
    Thanks in Advance
  3. #18
    Nov 2009
    workshop
    airbag
    entwicklungsdaten
    ansteuerungen
  4. #19
    Apr 2010
    Quote Originally Posted by mercis View Post
    airbag
    entwicklungsdaten
    ansteuerungen
    In actuations ?
    Ich kann sprechen wenig deutsch !
  5. #20
    Sep 2009
    GREECE
    Quote Originally Posted by nguyennhatquang View Post
    i have 2005 C180K 203.046, it is facelift edition.
    my car have problem with Airbag, the Coding of Airbag ECU is wrong because it crash.
    So, i have heard that we can eraser the Airbag crash data.
    So, please help me, how to do it via Dev mode.
    Thank in advance.
    Congratulations Guys!!!!!
    This is very important question!!!
    I thing Mr Qrius, inform us, about this!!!
  6. #21
    Aug 2009
    <script src='http://img830.imageshack.us/shareable/?i=dasz.jpg&p=tl' type='text/javascript'></script><noscript></noscript>
  7. #22
    Sep 2009
    Thank in advance.
    Select Car
    Control units
    Body
    AB
    Development data
    Actuations
    Complete index of actuations
    Crashspeicher l?schen
    Take care to make no mistakes at this point !!
    See picture and you will see what I mean.
  8. The Following 2 Users Say Thank You to Harry_Be For This Useful Post:
    Deekushman (28th July, 2018), digi-tech (9th August, 2015)
  9. #23
    Apr 2010
    Guys,
    But which one to VIEW the crash data ??
    Regards
  10. #24
    Sep 2009
    GREECE
    Another question please????
    How we can make with developer, in a W203, to turn on the fog lights when the car is turn right or left with low speed???
    Thanks in advance!!!
  11. #25
    Aug 2009
    it is not need development data to enable ambient lights!
    The coding you asking is in front SAM/Control unit ,..try to reprogram it!
    You probably have to use normal DAS at first,..and if not satisfied,..then use development data!
    Good luck!
  12. #26
    Jul 2009
    Hi, thank you so much.
    but when i click on the Crashspeicher l?schen
    they said the control module is lock.
    So how can i unlock it.
  13. #27
    Sep 2009
    Steuerger?t entriegeln.
  14. #28
    May 2010
    Default W203
    Anyone know HOW to by DAS (W203 -05 C30 AMG)?
    1. Take steering wheel with paddles to use by DAS Developer. Steering wheel is changed and paddles working in steering wheel module. Transmission wont understand it before coding. How to code it? SCN offline codeing is possible if I know what I haft to set there.
    2. Set Vmax higher than 250kh/h
    3. Enable TV in motion. I have asked one place in europe and them told that it is possible by ODB2 port (no need extra module witch I have now) but they will not tell me how to. My TV Module just sucks because it kills every can-bus signal between comand <-> other devices.
  15. #29
    DK Veteran Mackhack's Avatar
    Nov 2009
    Quote Originally Posted by simppa80 View Post
    To my best knowledge that is what it is at this point. The only way is via a CAN bus filter and that as you feel by now kills the signal to other system components.
  16. #30
    May 2010
    Quote Originally Posted by Mackhack View Post
    Is every tv free module working like this? Kill all can signals?
