Tips and Tricks using Das Developer edition
Page 1 of 38 12345611 ... LastLast
Results 1 to 15 of 569
    Qrius's Avatar
    Exclamation Tips and Tricks using Das Developer edition
    This started as a sugestion
    In here i will post my allready published developer tricks that are circulating around Dk
    From time to time i will add some new tricks as well
    Hope this will encourage others as well
    Last edited by Qrius; 30th April, 2011 at 08:10 AM. Reason: Removed a seller's name
  2. The Following 17 Users Say Thank You to Qrius For This Useful Post:
    al70 (27th July, 2022), alberto3a (2nd April, 2021), Col19 (13th November, 2019), diac (12th April, 2014), dzmitry (10th July, 2019), Eltarmo (18th March, 2021), gomarota (21st May, 2013), Hayssam1 (26th June, 2014), latino (19th June, 2013), MOBILTRONIC (5th January, 2022), mohamedkey (27th March, 2014), plore90 (28th November, 2016), sebastian (15th November, 2014), stanislav georgiev (26th June, 2015), stefaudio (21st September, 2014), test-mate (19th May, 2013), trafas (3rd March, 2016)
  3. #2
    Qrius's Avatar
    Exclamation How to: Enable tank info & L/100KM into KM/L mercedes W211 (W203) (w221) and more
    Here is how to do it,
    In Developer mode :
    Kombiinstrument -> Diagnose nach Werkangabe -> Steuergerate-Anpassungen ->
    Steuergerate-Anpassungen (Variantencoderierung) -> Variantkodierung Werkeinstellungen ->
    In the menu that shows , you scroll down untill you read the line : Tankinfo im Reichweitebild
    enable this option
    now you have tankinfo in the screen that otherwise only showed range
    If you allso wanna adjust the way fuel consumtion is showed
    you scroll a little more down untill you read the line : Verbrauchanzeige km
    you can change it from L/100km into km/l
    Scroll down and confirm Coding by pressingF3
    if you watch your Instrument Cluster , you notice that scrolling through the menu , nothing changed .
    For this , the "Kombiinstrument" needs a reboot.
    to do this in Developer mode we go back by hitting F1 -> 3 times
    then choose Ansteuerungen -> Gesamstliste aller Ansteuerungen ->
    Scroll down untill you see the line : Steuergeraet Resetten (PowerON-Modus) (FN_Reset_SG_Power_ON)
    Press F3 and confirm again with F3
    Now you will see the "Kombiinstrument" reboots
    If you think this would help you
    Please dot not forget to click THANKS
  4. The Following 25 Users Say Thank You to Qrius For This Useful Post:
    alberto3a (2nd April, 2021), Col19 (13th November, 2019), Deekushman (28th July, 2018), discouver (22nd September, 2016), gogoli (6th February, 2014), Grover2000 (27th September, 2013), Hayssam1 (4th May, 2017), JAYAUTO (30th September, 2013), kim sun sung (14th March, 2014), kina (4th April, 2020), kiwi1hu (8th April, 2013), latino (19th June, 2013), mende (17th November, 2015), mohamedkey (27th March, 2014), ph0en1x (11th December, 2013), plore90 (6th July, 2018), rabihfiras (10th June, 2019), raffaell0 (28th November, 2015), sebastian (3rd April, 2013), ssaliaj (14th October, 2016), Styffen (9th February, 2017), ToneZ (8th October, 2013), toutougsmserver (16th December, 2018), viviserifu (3rd November, 2019), Zohar (26th August, 2013)
  5. #3
    Qrius's Avatar
    Exclamation How to:Clean Full ASSYST Memory for W211 W219 and more.
    Here is how to : clean ASSYST Plus Memory
    All we need is DAS in Developer mode
    In Developer mode : (tested version 07-2009)
    Steuergerate (Control units) ->F3
    Aufbau (Body) ->F3
    ZGW (CGW) ->F3
    Entwicklungen (Development data) ->F3
    Steuergerate - Anpassungen (Control unit adaption) ->F3
    Programmieren (Update) von Steuergeraten (Control module programming) ->F3
    Steuergerat programmieren (Auswahl) (Program control unit (Selection)) ->F3
    Now we have 2 options to flash the ZGW/CGW with, choose the correct one
    Don't panic ! if you choose the wrong file , it terminates process and you can do it over again
    Confirm Flash pop-up with Ja (Yes)
    After that it says : "Das Steuergerate wurde erfolgreich programmiert"
    -> "OK" it ask for a reset -> JA (Yes) ->
    ECU Reset (FN_ECU_Reset) ->F3 again ->F3
    Now you Completed full History wipe out
    Everything discussed in this post is for experimental and educational purposes only
  6. The Following 18 Users Say Thank You to Qrius For This Useful Post:
    111arm (30th October, 2019), blueabyss (4th May, 2013), Col19 (13th November, 2019), danielboom00 (23rd April, 2015), esse (2nd April, 2019), gogoli (6th February, 2014), ION CRISTI (17th February, 2016), jackeldestripador (27th November, 2018), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), latino (19th June, 2013), mende (17th November, 2015), pbn (3rd February, 2016), ph0en1x (11th December, 2013), plore90 (20th May, 2019), raffaell0 (28th November, 2015), sebastian (3rd April, 2013), trafas (3rd March, 2016)
  7. #4
    Qrius's Avatar
    Exclamation SBC Sensotronic Brake Control reset
    Make sure engine is running !!!
    In Developer mode you need to go to Entwickelingsdaten - > ansteueringen -> Gesamstliste aller Ansteuerungen
    to see how many times brake has been pressed there is a line that says: Bremsenzahler (DJ_GetBrLive)
    then 1 line down there you see Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen -> click it !
    Parameter uINBR = 0
    then click F3
    1 line down Bremsenzahler auf beliebigen Wert setzen (DJ_SetNBr) -> click it
    Parameter uINBR = 0
    then click F3
    then scroll down untill you see the line's :
    Lebensdauerzahler F neu berechenen (DJ_CalcLiveTime)
    Parameter uINBR = 0
    then click F3
    Lebensdauerzahler F neu berechenen und schreiben (DJ_BuildAndWriteF)
    Parameter uINBR = 0
    then click F3
    Log out of SBC !!
    log out of verhicle !!
    let engine run at least 10 minutes or drive at least 10 minutes
    If no coils are damaged , SBC fault code is not AKTUEL nomore
  8. The Following 27 Users Say Thank You to Qrius For This Useful Post:
    111arm (30th October, 2019), Col19 (13th November, 2019), Deekushman (28th July, 2018), diac (12th April, 2014), dritan (21st January, 2017), esse (2nd April, 2019), Fec001 (19th September, 2013), foxibg (28th March, 2017), jackeldestripador (26th November, 2018), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), lexa-dok (25th April, 2013), mende (17th November, 2015), micmax4 (4th December, 2013), minchion (28th September, 2013), nick_f (9th September, 2015), raffaell0 (28th November, 2015), sabe (25th June, 2014), sazimam11 (7th October, 2017), sebastian (3rd April, 2013), Tadas chipDPF (29th October, 2015), tor2lehel (25th October, 2013), trafas (3rd March, 2016), treo (25th April, 2013), TULGEYWOODMAN (26th September, 2013), vageric (27th September, 2013), Zohar (26th August, 2013)
  9. #5
    Qrius's Avatar
    Exclamation How to: Enable Comand DVD/TV Verhicle in Motion (W211 W219) and more..
    In Developer mode :
    Audio, Video, Navigation und Telematik ->F3
    a screen might pop up with all kind of settings, ignore and press F2
    New screen with ESD warning ->F3 COMAND /AUDIO -AUDIO 50 oder COMAND ->F3
    Entwicklungsdaten ->F3
    Steuergerate-Anpassungen ->F3 Steuergerate-Anpassungen (Variantencoderierung) ->F3
    HU Parameter ->F3 scroll down to line: Driving speed is more than 0 kph and
    Driving speed is more than 10 kph and BOTH enable them and ->F3 to confirm coding
    Now you be able to watch DVD/TV when car is in motion
    This procedure won't work for W204 W221 and newer models
  10. The Following 15 Users Say Thank You to Qrius For This Useful Post:
    111arm (30th October, 2019), 219buster (17th October, 2013), Col19 (13th November, 2019), F0RM (29th April, 2013), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), latino (19th June, 2013), mende (17th November, 2015), mohamedkey (27th March, 2014), poker (21st August, 2015), raffaell0 (28th November, 2015), sebastian (3rd April, 2013), Tadas chipDPF (29th October, 2015), trafas (3rd March, 2016), Zohar (26th August, 2013)
  11. #6
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Nicely done - Very nicely done.
    Our sincere Thanks to Qrius for all the time and effort he continuously injects to the Forum. His contribution to the success of DK is invaluable.
    G.
  12. #7
    Jun 2009
    Quote Originally Posted by Qrius View Post
    In Developer mode :
    enable this option
    If the menu you get does not have this Tankinfo im Reichweitebild line, search for the line Bild Reichweite ohne Tankinfo and disable it. Then, look for the line Bild Reichweite und Tankinfo and enable it.
    These procedures should work on all w203, either one way or the other.
  13. #8
    Hello everybody
    This thread was created by Qrius in order to contain in one thread all the tips and tricks using Das Developer edition .
    May I ask you please NOT TO VANDALIZE IT with comments like "I am going to try it" , "test" . Newbies can be excused for trying to improve their "Posts Statistics"
    I am not trying to be clever, I am only trying to keep this thread free of noise so everybody can benefit by finding all those tips and tricks in one place
    All the best from sunny (flaming really with 40 C) Athens
    G.
    P.S. I am going propose again to moderators to rub out all non relevant messages. Just leave a clear notice requesting NO NOISE !!!!
    Last edited by PremierD; 16th June, 2010 at 01:52 PM. Reason: No longer Relivent ..............
  14. The Following 2 Users Say Thank You to gmatj For This Useful Post:
    Col19 (13th November, 2019), dimss89 (2nd November, 2017)
  15. #9
    Qrius's Avatar
    Exclamation How to:Add Tempomat/Cruise control for W639
    Here is how to:
    Add cruisecontrol / limiter to your Vito/Viano W639 it's configuration.
    This should work for all W639 till AJ08
    In Developer mode :(tested version 10-2008)
    In engine control unit:
    Password : flexecu ->F3
    VCD_Transporter->F3
    a Pop-up tells you : "Mindest eine Codiereinstellung ist ungultig" confirm -> OK
    Here you will find the option settings
    write down the line that is blue.
    For example : NSG or NAG_Klima_Wasserstandschalter
    Now we search for the string that contains the same options + Tempomat and Begrenzer
    So that will look like : NSG or NAG_Tempomat_v-Begrenzer_Klima_Wasserstandschalter
    Once you find it , click it and confirm with ->F3
    "Soll die Codierung in Steuergerat ubertragen werden ?"->F3
    JA or YES->F2 to proceed
    Now we log out the engine ecu and go to the :
    Instrument Cluster ( Kombi instrument) (Magnetti Marelli)
    Variantencoderierung Algemeine Daten->F3
    Scroll down untill you see "Limiter" set to Ja or Yes ->F3
    F2 -> F1 -> F1
    Cruise control coding is added succesfully to your W639 now
    As for the cruisecontrol handle itself.
    On the back of the EZS you notice there is place for 1 connector , this is where the cruise-contol handle will be plugged it.
    Hope this will help any of you
  16. The Following 8 Users Say Thank You to Qrius For This Useful Post:
    clauberty (17th May, 2018), Col19 (13th November, 2019), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), latino (19th June, 2013), PierreTheron (26th April, 2013), pstryk74 (23rd September, 2022), sebastian (15th November, 2014)
  17. #10
    Quote Originally Posted by battle77 View Post
    pls more !!
    w211
    - Airmatic to lower ... ?
    - activate Bending light ?
    and and ...
    Thanks a lot !!
    Why my friend you do not read a few posts above ????? (post #8)and help keep this thread free of noise - This is no a place for requests that come suddenly in your head .
    More tricks will be published as soon as they are prepared and tested. Just subscribe to the thread and you will be notified !!! It is that simple...
  18. The Following User Says Thank You to gmatj For This Useful Post:
  19. #11
    Qrius's Avatar
    Default How to: Enable tank info W639 & W906 facelift
    Those who want to enable tankinfo on a W639 & W906
    Should follow procedure as in post #2
    But will find "Tankinfo in Reichweitenbild" in menu Reiserechner 1 .
    All the rest remain the same
  20. The Following 3 Users Say Thank You to Qrius For This Useful Post:
    Col19 (13th November, 2019), latino (19th June, 2013), sebastian (15th November, 2014)
  21. #12
    Default Cruise control
    Is the info for activating cruise control on the 639 the same on a 906 sprinter please?
  22. #13
    i have 2005 C180K 203.046, it is facelift edition.
    my car have problem with Airbag, the Coding of Airbag ECU is wrong because it crash.
    So, i have heard that we can eraser the Airbag crash data.
    So, please help me, how to do it via Dev mode.
    Thank in advance.
  23. #14
    DK Veteran cocoh's Avatar
    Jun 2009
    hello..
    Mr. Qrius...
    please, May you explain how I can to control the real kilometers on a car? how I realize IF WERE changed or not?
    What methods are they?
    thank you
  24. #15
    question from a newbie ...
    what is DAS and where can i get it ? do i need any other hardware ?
    I am mainly interested in activating tv in motion
    Thanks.
