Results 1 to 5 of 5
    Default dash dump 93c86 4b0 920 933m (D07)
    Hi to all,
    i need dump for dash 93c86 4b0 920 933m (D07) may bin is def.
    J need new bin or repair (dzis.bin)
    Control Module Part Number: 4B0 920 933 M
    Component and/or Version: KOMBI+WEGFAHRS. VDO D07
    Software Coding: 00160
    Work Shop Code: WSC 00481
    Additional Info: WAUZZZ4B12`4B1 AUZ7Z0A1893009
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    PIN 1270
    A6 2,5 tdi 2001r
    vin WAUZZZ4B12N019320
    Default Allroad
    Hi do you know what vag tacho do i have to buy in order to change an allroad 2002 with KOMBI+WEGFAHRS VDO D07, i bought a chinese vag tach with 2,5 and then blocked with 3.0....
    Please help
    DK Veteran jruibarroso's Avatar
    Dark Side of the Moon
    where it is
    please don't forghet to thank
    Member hadrian's Avatar
    I need 4B0 920 933 G VDO 07 crypted dump for similar reason. I greatly appreciated if you search in your collection for this model.
