Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 83
  1. #31
    racin-snake's Avatar
    Jun 2009
    i use gq4x usb programer also have a wellon vp490
    gq is quick and cheap and with adapter works fine on both f200 and f400
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  2. #32
    PierreTheron's Avatar
    Centurion,South Africa
    Default GQ 4x
    Received my willem adaptor and did my first read on 29f400 chip.
    Seems to work great.
  3. #33
    magnacin's Avatar
    I have been using GQ-4X with adapter. it is good and reliable.
    check this website:
    A low cost EPROM EEPROM MCU Atmel Microchip PIC I2C SPI programmer online store
  4. #34
    DK Veteran zogldi's Avatar
    Space
    I use Xeltek SuperPro 3000 and never had problems with reading flash,eprom,mcu... This device have all adaptor one to one and you can make it you self.Reading and writing is 100%.By the way I have Galep4 too but Xeltek is much better.
  5. #35
    Top Poster + DiegoAC's Avatar
    Gq-3x and gq-4x work fine for that. Cheers.
  6. #36
    Ukraine
    I'll try it - New EZoFlash+. Parallel memory programmer.. Now the stage of assembly. Assemble, test it, tell about it
    Sorry for bad English
  7. #37
    Ukraine
    What you can edit the downloaded dump 29F800 or 29F400?
    So need a program for editing calibrations in the dump.
  8. #38
    mexanico1971's Avatar
    portugal
    Default flash 29f400 width willem and adapter
    hello ! I have some problem width my psop 44 adapter in my pcb 3.5. i can not erease the 29f400 but i can read something !
    I try to make shore if the pins are good contact and it seems ok !
    this is a 29f400 from a bosh edc15 Peugeot 206 hdi !
    I install the newest willem 5.5 and I see some diferences in the 97ja and the 99d8 !
    why ?! is there any reason ?!
    I gona lef one attachement !
    if somebody cant help me ![IMG]file:///C:/DOCUME%7E1/VIRALA%7E1/DEFINI%7E1/Temp/moz-screenshot.png[/IMG]
    thanks in advance !
  9. #39
    bram380's Avatar
    Indonesia +628153111774
    Try to select a device Flash 29/39/49Fxxx,
    and select 29Fx00 8/16bit,
    then select AM29F400.
    Do not forget to attach 12Volt DC power supply.
  10. #40
    portugal
    Quote Originally Posted by bram380 View Post
    hi ! the problem was the program ! I have the pcb3 and do not work width 99d8 only 97ja !
    another thing its clean very well the contact pins !
    and I do the job !
    thank you very much !
    nice video !
  11. #41
    Sent from iPhone 4S
  12. #42
    busaman's Avatar
    suffolk uk
    i use wellon vp480 so far had no problems with any chip including the am29fxxxx series.
    7.31sec@203.3mph
  13. #43
    Apr 2011
    PROGRAMMER EEPROM
  14. #44
    ALGERIA
    i use willem with 98D12C3 soft version
    PERFECT
  15. #45
    DK Veteran elchip's Avatar
    EU
    Post
    Quote Originally Posted by SergoFox View Post
    EzoFlash HW v4.5 is the best solution for smal amount of money , it work better then willem and last willem SW with it.
    I was make and test many many times and newer false.
    Always do ID first and if you dont get right ID from device do not program !
    Check connection's and test again.
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
