Results 1 to 1 of 1
    Dec 2023
    Default Need help with 03-ABS coding
    Hello.
    I realy fuc*&% up a few days ago and changed wrong byte and bits in 03-ABS, Now its lots of fault codes.
    When i try to change the byte back to 20 i get: Coding rejected Error 31 out of range
    I tryed to disable ASR/ESC and i did, But tcs, abs, and TPMS is glowing in the dashboard!
    i made backup of everything 1 year ago but that usb stick is dead.
    Ill hope someone here can help me out.
    Its a skoda octavia mk2.5 VRS 2010
    Thursday,28,December,2023,20:05:43:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 23.3.1.0 (x64)
    Data version: 20230421 DS346.2
    www.Ross-Tech.com
    Dealer/Shop Name: Privaten
    VIN: TMBUH61Z3A2101033 License Plate:
    Mileage: 207080km-128673mi Repair Order:
    Chassis Type: 1Z-SK35 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2B 42 44 46 4C 52 55 56 62 72
    VIN: TMBUH61Z3A2101033 Mileage: 207080km-128673miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Not registered 0001
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Not registered 0011
    46-Central Conv. -- Status: OK 0000
    4C-Tire Pressure II -- Status: Not registered 0001
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 RD HW: 03L 906 022 GA
    Component: R4 2.0l TDI G000SG 9977
    Revision: 13H03--- Serial number:
    Coding: 0000072
    Shop #: WSC 83968 792 591558
    VCID: 78FF5DE70BD34253F3-802C
    VINID: 91D4A560606A0D10810010030C5BA490FC
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1-AJ.lbl
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 143B601C092200FB280B06E7901C0042340C00
    Shop #: WSC 73430 790 00999
    VCID: 78FF5DE7CBD34253F3-802C
    7 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 200
    Mileage: 207048 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 02:08:17
    Freeze Frame:
    Count: 2
    Count: 32768
    Count: 4608
    Count: 328
    Count: 53013
    Count: 223
    Count: 61440
    Count: 0
    01542 - Yaw Rate Sensor (G202)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 200
    Mileage: 207048 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 02:08:17
    Freeze Frame:
    Count: 2
    Count: 32768
    Count: 4608
    Count: 327
    Count: 53013
    Count: 223
    Count: 61440
    Count: 0
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 00:56:45
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12800
    Count: 320
    Count: 50432
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 00:56:45
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12800
    Count: 166
    Count: 50432
    Count: 0
    Count: 0
    Count: 0
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 00:56:45
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12800
    Count: 295
    Count: 50432
    Count: 0
    Count: 0
    Count: 0
    01309 - Power Steering Control Module (J500)
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 00:56:45
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12800
    Count: 8212
    Count: 50432
    Count: 0
    Count: 0
    Count: 0
    01487 - System Function Test
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 161
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 01:00:10
    Freeze Frame:
    Count: 2
    Count: 0
    Count: 4608
    Count: 321
    Count: 50488
    Count: 1
    Count: 768
    Count: 0
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
    Component: Climatronic H15 0401
    Revision: 00005001
    Coding: 0000000002
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_ClimaAutoBasis_SK35.rod
    VCID: 03053A0B8A15118BD6-8056
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
    Component: BCM PQ35 H 103 0575
    Revision: 00103 AG
    Coding: 00180AB8B85BB3C0C0080080110091E4437000AE626D8560E4 0440040000
    VCID: 326BAFCF6D2F68030D-8066
    Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 20021 22 0601
    Coding: 00DFB7
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 180210 05 54 0403
    Coding: 0730ED
    Subsystem 3 - Part No: 1Z0 951 171
    Component: Innenraumuebe 008 5101
    6 Faults Found:
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 206941 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 05:48:55
    Freeze Frame:
    Term 15 On
    Voltage: 14.15 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 206941 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 05:48:55
    Freeze Frame:
    Term 15 On
    Voltage: 14.25 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    01504 - Bulb for License-Plate Light (X)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 24
    Reset counter: 160
    Mileage: 206941 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 05:48:59
    Freeze Frame:
    Term 15 On
    Voltage: 14.15 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    01598 - Drive Battery Voltage
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 6
    Fault Frequency: 10
    Reset counter: 201
    Mileage: 206941 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 05:50:19
    Freeze Frame:
    Term 15 On
    Voltage: 13.95 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    03156 - Sensor for Anti-Theft System (G578)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 199
    Mileage: 206949 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.85 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 20
    Reset counter: 200
    Mileage: 206949 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 21:03:44
    Freeze Frame:
    Term 15 On
    Voltage: 11.65 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
    Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
    Component: PARKHILFE 4K H06 0006
    Revision: -------- Serial number: 66641005003453
    Coding: 100002
    VCID: 408FF507D383CA938B-8014
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q6 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD2K24B2
    Coding: 0020790
    VCID: 3D718CF36471A77BE0-8068
    Subsystem 1 - Serial number: 6332MSME4F206D43I
    Subsystem 2 - Serial number: 6342MSME50142A510
    Subsystem 3 - Serial number: 6351HSME203A1332Y
    Subsystem 4 - Serial number: 6361HSME203B5C1FH
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
    Component: J0527 053 0111
    Coding: 0000034
    VCID: 03053A0B4215118BD6-8056
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 1Z0 920 803 J HW: 1Z0 920 803 J
    Component: KOMBI H05 0305
    Serial number: 00000000000000
    Coding: 110E00
    Shop #: WSC 73430 031 00999
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
    VCID: 3B7582EBB265A94BDE-806E
    Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H16 0233
    Revision: H16 Serial number: 4520K102200714
    Coding: A9A17F04000202012302
    VCID: 69D908A34079EBDB7C-803C
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 206825 km
    Time Indication: 0
    02811 - Control Module for Electronic Steering Column Lock (J764)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 206825 km
    Time Indication: 0
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 160
    Mileage: 206825 km
    Time Indication: 0
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0305
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6ADB77AF8D7FE0C375-803E
    Address 2B: Steer. Col. Lock
    Cannot be reached
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
    Component: Tuer-SG 009 2113
    Coding: 0004340
    VCID: 489FED273BB3F2D343-801C
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 74 3001
    Revision: 00H17000
    VCID: 3169A0C3A829531B74-8064
    1 Fault Found:
    00750 - Warning Lamp
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.13 V
    DD
    Temperature: 26.0 C
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 4C: Tire Pressure II
    Cannot be reached
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0000244
    VCID: 479DEE1B36ADFDAB4A-8012
    Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0142
    Revision: 00H04000 Serial number:
    Coding: 1507354
    VCID: 3467A9D7573B66331F-8060
    Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l 0005
    Coding: 00000023
    Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r 0005
    Coding: 00000023
    1 Fault Found:
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 206949 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 21:57:50
    Freeze Frame:
    Voltage: 13.63 V
    Speed: 0.0 km/h
    ABS 1
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
    Component: BOLERO 009 0053
    Revision: 0A001001 Serial number: SKZ1Z3K8440093
    Coding: 0D0004000401
    VCID: 356194D39C417F3B28-8060
    2 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 00:21:32
    03138 - Input AUX IN
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 206987 km
    Time Indication: 0
    Date: 2018.05.20
    Time: 00:21:27
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 73430 790 1012551
    VCID: 326BAFCFAD2F68030D-8066
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
    Coding: 0000144
    VCID: 3365AACB5235610B06-8066
    End-------------------------(Elapsed Time: 02:35)--------------------------
