Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
  1. #31
    Mar 2008
    Not sure as I won't put gemini on my box (clone killer) but is'nt gemini a maxvar image ?
    Not sure if this method works with maxvar images ? you could try specifying the blocksize with -b <blocksize> , I think the default is 65535
    ./mksquashfs -help
    will give more info
    Another thing to check is that you have the correct version of mksquashfs.
  2. #32
    Jan 2009
    how to know which version i have to use? i used 2 versions and still same...
    maybe as you said... i have to mention the size also... once i reach home i will give it a try....
  3. #33
    Junior Member drhg's Avatar
    Apr 2008
    every where
    Quote Originally Posted by baderh View Post
    just use mksquashfs with lzma patch & all will be ok
    note that all squashfs parts in the recent images need mksquashfs with lzma patch to be recompressed in right way ( pli needs mksquashfs 3 with lzma)
    hope this help
    cheers
    drhg
    Dreambox Developer
    --CLi Team--
    --U.R Team--
  4. #34
    Nov 2008
    Devilfish hi
    how i can extract all xxxx.img and compress this after edit enything
    plase
  5. #35
    Jan 2009
    this method works with mtd0 too?
  6. #36
    May 2008
    22222222222222222222222222222222
  7. #37
    Sep 2008
    Hi All
    Perhaps the ones who got this to work could let us know which distro they are using and any additional software they installed on there x86 machine.
    I couldn't get this to work with Slax 6.1.1 mounted on HDD which has squashfs-lzma 3.x support built in. I don't know how to check if the byte order patch has been built in to squashfs? PPC big endian, x86 little endian.
    I did get a different solution working tho using the dreambox itself to put the image back together after editing.
    1. On the dreambox mount an NFS share to your x86 machine.
    2. Create a swap file, format it and turn on swap.
    3. Put your tools and image you want edit in the mounted HDD.
    4. Now you can open a complete image, edit it then pack it back together again.
    Tools and scripts needed:
    mkcramfs
    mkdreamboxfs
    mksquashfs
    uncramfs
    undreamboxfs
    NOTE: The tools I have will not pack it as the same version of squashfs as the newest images, so the image will be slightly larger, but I can CONFIRM this works.
    PS
    This is not a tutorial, just a summary of what I did to edit an image. If there is much interest I will try and document more of what I did.
    Best regards
  8. #38
    Apr 2009
    I followed the steps by devilfish using ubuntu 9.04...
    I got upto "
    ./mksquashfs root mtd5.img -be
    After putting in that command I got the following error:
    bash: ./mksquashfs: No such file or directory
    So I tried the above command without "./" at the begining of mksquashfs and it created the image...I then typed the following in telnet:
    cd /tmp && eraseall /dev/mtd/5 && cp mtd5.img /dev/mtd/5 && reboot
    It erased successfully but then gave the error:
    cp: Write Error: No space left on device
    I did not make many alterations...I also tried the above process without any changes but still got the above error...
    Any suggestions on how to resolve this? Thanks
  9. #39
    Sep 2008
    @badboy123
    Try a reboot of the dreambox before you FTP mtd5.img back to the dreambox, lets us know how you get on.
  10. #40
    Apr 2009
    I tried rebooting before I uploaded the image but still the same issue...do you have any other suggestions?
  11. #41
    Sep 2008
    @badboy123
    What is the size of your .img file?
  12. #42
    Apr 2009
    5.29 MB...This transfers across with no problems
  13. #43
    Aug 2008
    Are you using mksquashfs from the the dreambox cdk?
     /home/ubuntu/tuxbox-cvs/root/cdkflash/mksquashfs
  14. #44
    Apr 2009
    I wasnt using that mksquashfs...tried it with that and managed to sort it out...
    Thanks.
  15. #45
    Nov 2008
    Default Black Screen issue
    Hi Guys
    I too kept experiencing the blank screen issue after following the Devilfish Tut. I found that the problem was down to the wrong mksquashfs file. The one attatched works perfect for me. Put it on my Desktop (Ubuntu) along with the tuxbox-cvs & root directory. The ''./mksquashfs'' is a correct command. A big thanks to Devilfish for an excellent Tut.
    Wizard
