Results 1 to 7 of 7
    Portugal
    Default Problems reading MC68HC11A1 with UPA
    Hi friens.
    I have an ECU from Peugeot 406 IAW8P.14
    It uses an MCU 68HC11A1, in Upa PDF it doesnt exists and I am trying to read it like MC68HC11A8 they are equal.
    I am not beig able to read it, allways TXD and RESET error, already lift the pins but the error stills appearing and I cant read it.
    Anyone already has this problem and have a tip how to read it?
    Best Regards to all.
    Nuno
    BATLER
    Guest
    i had problem with motorola 2 ,i had lift the pin tha pdf said but with no success ,until dk forum gave me the solution by giving external power TO UPA and lifting rx dx reset only
    :http://www.digital-kaos.co.uk/forums...hc11f1-116103/
    DK POWER 1!!!
  3. The Following User Says Thank You to BATLER For This Useful Post:
    chafik4051 (22nd April, 2017)
    Portugal
    but that worked in 11f1 MCU, already tried in 11A8 and no sucess.
    I dont know why I am not being able to read it, maybe the MCU is the ECU problem and is damaged.
    I dont know what to do anymore.
    Regards and thanks fo the reply mate.
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Try next; connect all pins with wires and then take mcu between four fingers and try reading.That mcu,i have several times successfully programmed in such a way.Regard.
    Portugal
    thanks mate.
    finally took it out of circuit, connected all the wires and crystal i the pins.
    At first attempt it worked, problem solved.
    But this is strange because already tried again with the same method and it doesnt read again, I must do "read" for 10 times maybe and after a lot of tries it reads.
    Well, it is solved and I think the best way is to take it out of circuit and read.
    Regards,
    Nuno
    Jan 2014
    Quote Originally Posted by BATLER View Post
    DK POWER 1!!!
    READ WITH SUCCESS
    THANKS
    Jan 2014
    Default CONNECTION
    peugeot 406 MC68HC11A1.zip
    FINALY READ WITH SUCCESS
  9. The Following User Says Thank You to chafik4051 For This Useful Post:
    mnem (11th December, 2022)
