Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Sep 2008
    Default Wii Brick Blocker
    Here is a very useful tool the Wii Brick Blocker Tool. For example if you own a PAL Wii and you download an NTSC game ISO that may contain a wii update this may brick your wii not good. This tool should remove update from the ISO image before you burn it to disk.
    Happy Days
    Digital Kaos - Downloads - Wii Brick Blocker Tool
    Feb 2009
    Recently had my PAL region Wii chipped and want to play NTSC (and maybe Jap) games on it.
    I know i need to use Brick Blocker but i'm a bit of a newbie so just wondered if it is fairly quick and easy to use and if there are any 'pitfalls' to look out for.
    Cheers
    Braders
    Mar 2009
    wii brick blocker is fairly quick and easy to use. all you have to do i just select your iso and it does the rest for you.
    Apparently you dont need to block games that are of your reigion e.g PAL game with a PAL wii should be safe to leave unblocked.
    Mar 2009
    I am new to this site, I have downloaded the "wii brick blocker" it works on my laptop running windows xp home edition, but it will not work on my main pc which runs windows professional... anyone got any ideas??? All I keep getting back is a message which reads "The application failed to initialize properly (0xc0000135). Click on OK to terminate the application. Can someone please help!!??!!
    V.I.P. Member dell_xps's Avatar
    Quote Originally Posted by bella View Post
    You probably have microsoft net framework installed in home edition, install it to your main PC.
    Apr 2009
    Default e
    sweet thanks
    May 2009
    thanks a lot
    Jun 2009
    Thank you m8
    Default New version?
    Is there a newer version?
    Thanks for this
    good, that's great thx
    Default How does this actually work?
    Just wondering if anybody knows the details of how this brick blocker actually works?
  13. #13
    Top Poster delboy71's Avatar
    Nov 2008
    Quote Originally Posted by rickuski View Post
    wii brick blocker just removes the system update section out of the iso.
  14. #14
    V.I.P. Member ck-ok's Avatar
    nottingham
    All BrickBlocker does is replace the partition containing the update with one from a game that does not have an update on the disc.
  15. #15
    Victoria - Australia
    Hi there I am a newbie 2 & was wondering if there woz a newer version of Wii Brick Blocker ? & if not doe this version apply to all games out and versions of 4.2 ?
    Thanks.
