Page 7 of 11 FirstFirst ... 234567891011 LastLast
Results 91 to 105 of 156
  1. #91
    Nov 2008
    i have connected my dreambox to the router with a cross over cable to one of of the routers ports and a standard cable to the computers eternet connection tried using flashfxp as described but just keeps saying connection failed have put in ip adress of dreambox any ideas
  2. #92
    Aug 2008
    Default how u connect your box
    hya i have currently got the eurovox ultra box but somehow i can not connect up the box by using the FlashFXP. i have the null cable in and the power cable but i get stuck wen you try and connect your box to your pc. i have the ethernet cable and i tried using the ethernet/router process, i use root and dreambox for my user and password my i.p adress on my box is 192.168.0.24 but my i.p adress on the pc is 82.4.127.115 and i hear something about they got to be the same can n e 1 elp and can something explain to me or show me a diagram on how you connect your box to your pc much appreicated thankyou
  3. #93
    Top Poster cjjthedon's Avatar
    Aug 2008
    earth
    im stuck on where to get my channels bk , i got flash fxp connect to dbox np , now im stuck what to do next
  4. #94
    Nov 2008
    hi, can you help coz i tried all this and dunno wat went wrong but now my dreambox wont even let me watch normal tv..... can you tell me what the original communication setup ip was and i will try manually. will look into this and try again in a few days. im fed up with all this now. thanks m8
  5. #95
    Newbie insomniac2k's Avatar
    Jan 2009
    Default DM500c - Login incorrect when connecting
    Can any1 help?
    I'm trying to connect to my dreambox using flash fxp in the usual way. IP and everything is correct - I've done it many times on a DBox2. For some reason the username and password are not accepted. I'm using: root:dreambox. It's got a neutrino open media image and the camd.cfg file has the credentials as root:dreambox too but it always fails.
    Tried pinging the box fine and telnet also comes back with login incorrect.
    Any help appreciated !!
  6. #96
    Jan 2009
    Got the fix from another thread.
    http://www.digital-kaos.co.uk/forums...34/#post138240
    DK Rocks !!!
    Quote Originally Posted by insomniac2k View Post
    Can any1 help?
  7. #97
    Nov 2008
    Cambridge
    Default Dreambox 500c - Keys Problem?
    Hi all, totally new to all this with limited computer skills, but thanks to Thommo & Devilfish for all of the guides on the site, I have managed to load a new image and used Thommo's instructions to load new keys via FlashFXP. Problem I have is that I can only see the non-encrypted channels. EPG shows all the details of the SKY ones, but when I select one it tries to load but then I get a black screen - any tips to check on settings or suggestions to make sure I have loaded everything onto my 500c correctly would be greatly appreciated.
    I have a new Digital Kaos image and the screen interface is different from the previous one I had - DigitalWorldz I think. All the connections via the router and the loading of the keys loaded as expected - just think there is some small thing I am missing to getting access to all of the cvhannels I had - I am on VirginMedia by the way. Hope someone might have a solution!
    Thanks - Mainman
  8. #98
    Feb 2009
    got the same prob
    can't ping the dreambox or anything else
  9. #99
    Newbie tellstar's Avatar
    May 2008
    Manny Thanks for your time given to this
    "ITS PEOPLE LIKE YOU THAT MAKE THE WORLD A BETTER PLACE TO LIVE IN"
    Best regards
    Tellstar
    Ireland/ Spain
  10. #100
    Feb 2009
    I keep getting connection failed already flashed the dk image to dreambox but cant get it to connect to txp
  11. #101
    Apr 2009
    hi, i dont seem to have a keys folder
  12. #102
    Apr 2009
    forgot to mention mines is just new out the box thanks
  13. #103
    Mar 2009
    Default no keys folder in var..
    when i go into var on my 500c there is no keys folder or scce folder... there is a keys and scce folder in var_init but i cant transfer to this folder... any suggestions thanks..
  14. #104
    Apr 2009
    Brazil
    Im getting the same error as johnhunt03 when copying the files to the keys and sccce folder
    Error 553 - Could not create the file.
    Any idea?
  15. #105
    Apr 2009
    Brazil
    Ok found the problem... my was that I was sending to the incorrect place (/var_init) when should be just (/var)
    Thanks all, and maybe can help others...
    Cya
