Results 16 to 30 of 33
  1. #16
    DK Veteran hercamp's Avatar
    yeah u right ...and all .friends that apport are right too.....100% true....just removed the board and the the engine start inmediately ...just the engine light on but the real problem now is solved.
    manu thanks.
  2. #17
    Fallen's Avatar
    I love it when a plan comes together!
  3. #18
    Meat-Head's Avatar
    Quote Originally Posted by Fallen View Post
    You crack me up Meat-Head, I demand we have a beer one day!
    Right just got an e-mail from Meat-City-Train Co.
    Just the journey from Meat-City to either Dover, Hollyhead, Glasgow
    or which ever way you are is an increasing amount daily
    Sorry that's going to be an expensive beer dude
    Here is the link they sent
    www.meat-city-trains.co.uk/price_for_meaty
  4. #19
    Fallen's Avatar
    The trip may cost a bit mate but once you get here you can crash on the spare sofa for a $1000AU a week (thats about 2 pounds 20p)!
  5. #20
    Meat-Head's Avatar
    Quote Originally Posted by Babanovski View Post
    100% if you remove small board car will start but yellow lamp will stay on.
    BUMP:
    Myth confirmed.
    Unplug and skank the immo box, (from memory) far right pair of wires, black/blue join to black, golderen oppertunity for a Scotch-lok
    As you crank wire becomes live, through starter inhibit relay.
    Small board
    1) Unscrew lid, wobble back and forth till it snapps off
    2) Unsolder untill out, watch for SMD resisitors
    Took approx 15 mins, including looking at ~~~~ on the net
    VERY easy to do.
    Yes MIL light will be one, find the wire at ECU first and cut before you immo off, yes you have to
    a) Cranck long time for it to start
    b) Wait a few seconds then cranck - instant start.
  6. #21
    Oct 2010
    Greece
    well hi all...
    i also have problem with a CRV honda ...lost keys and i could not find the obdII plug to program new keys...as i read above there is a solution ,does anyone have any photo's from the ecu to help ??
    thanks for helping !!!
  7. #22
    barelang-kepri
    No need remove small board. Just write to oki 8 pin FF FF 00 to last bite.
  8. #23
    calin_bm's Avatar
    near civilization
    BUMP:
    Myth confirmed.
    Modulo 18 - Honda, Acura immobox Megamos
    Memoria serial memory 93c46 SMD8 package.
    Tama?o 128 bytes.
    Use T5 transponder.
    El transponder escrito esta listo para arrancar el vehiculo.
    Vehiculos equipados con este modulo:
    Honda: Accord(-1999), Civic(-2001), CR-V(-2000), Integra, Legend, Passport, Prelude, Shuttle(-2000)
    is this the immo box?
    the 2 wires need to be together so the car can cranck,right?
    thank you.
  9. #24
    Hi all,
    Tried all the suggestions above on 2001 Prelude but when I remove the small board, no communication with pcm and car won't start.
    Any suggestions?
  10. #25
    martij976's Avatar
    I think Prelude have different setup. There spouse to be small black box located on the end of steering column under the dash.
    Wires from ignition antenna are connected to it. There is eeprom inside... But not sure how to bypass that. There was post about that before.
  11. #26
    Quote Originally Posted by martij976 View Post
    Read them all m8, still same, no go...............
  12. #27
    Meat-Head's Avatar
    Quote Originally Posted by raddi View Post
    Weird, it's a honda, they don't actually go wrong.
    Sounds like and only a sounds like the pgmficuk relay either behind the glovebox or under the drivers side.
    use the search botton
  13. #28
    Top Poster Digital Auto's's Avatar
    BUMP:
    Myth confirmed.
    Small board
    VERY easy to do.
    If the bypass board is fitted from Doc, does the MIL/Immo light operate correct and will the car start normally without waiting. thanks...
  14. #29
    Meat-Head's Avatar
    no idea try filling oki with ff
    read as 93c46
  15. #30
    DK Veteran buga37's Avatar
    USA
    Quote Originally Posted by cardoctor View Post
    Anyone tried this solution yet?
