Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Villa Maria, CBA, Argentina
    Default Honda CRV 1999 IMMO OFF
    Hi guys, i have in the workshop a Honda CRV 1999 and i need immo off because the red key are lost and the immobilizer code reader unit is bad. The car crank but not start and the immo light is blink.
    In my country, Argentina, the immobilizaer code reader unit or Solutions like Doctronics Mobilizer FX01 dont exist in the market.
    The ECU model is 37820-PHK-Q51 / 1265-107448 1I28.
    The ECU have the immobilizer board FX01 inside.
    Also, the ECU have a 93c46 EEPROM inside.
    Please tell me if exist any solution to the problem like immo off dump or how to bypass the immobilizer.
    Thanks in advance!
    Best regards from Argentina!
    Quote Originally Posted by vteco.performance View Post
    Hi my friend!
    In my country its no available this solution, i live in Argentina, doctronics are located in Austria, and dont have local reseller =(
    Thanks!
    Any other solution????
    Quote Originally Posted by kronos2k3 View Post
    Hi my friend!
    Thanks!
    hi! they send it to you i guess.
    this is one of the best solutions i've found for hondas.
    cheers
    dimitar's Avatar
    Default hi
    some guy on a russian forum said you need to remove the small vertical board only. Maybe you should try that
    Junior Member Lamparita's Avatar
    Hola.
    Lee la memoria 93c46, mandame un privado con el archivo leido o sube el archivo al foro y te paso los 32 digitos para armar un transponder que te arranca el vehiculo.
    Saludos.
    Lamparita.
    Hey men you just have to remove the little board located inside the ECU and it will start the only thing its that u have to wait to the D indicator turn off so u can star ur vehicule i have test it on many 99 Honda Accords and CRVs
    Fallen's Avatar
    I think this is the OKI board we are all talking about.
    The word on the Meat, I mean, street, is that the immo light will stay on though.
  9. The Following User Says Thank You to Fallen For This Useful Post:
    dutciuc (7th February, 2020)
  10. #9
    Meat-Head's Avatar
    Quote Originally Posted by Fallen View Post
    Yes "there is a rumar which says" that you are correct
  11. #10
    Fallen's Avatar
    You crack me up Meat-Head, I demand we have a beer one day!
  12. #11
    Meat-Head's Avatar
    No for one reason, and one reason only!
  13. #12
    I usually edit the rom to disable the immo on that. Does removing a board in there really work? I'd be surprised but Doc's little pulser thing seems to work.
  14. #13
    Meat-Head's Avatar
    Quote Originally Posted by d00f View Post
    hi, welcome to dk the woprlds best website.
    would you be kind enough to explain what rom, what with and what value.
    long live DK
  15. #14
    DK Veteran hercamp's Avatar
    I have one that ...not runn...cranck but the ignition coil ..its not working ,also the iyectors pulse.
    in a first time did I desable inmo*** with the red key,but now when turn ignition on the red key turn off after 4 seconds and check engine light too, but in ignition coil the ignition signal only is present for 5 seconds,
    I checked the 12 green/wh and ground but the ignition module has one signal that return from ecm ,this only flash for 5 second after that comes 6 v without flashes.
    if a remove the litle card before post ,u know if that can works??
    thanks ,for any help
  16. #15
    Busswil Switzerland
    100% if you remove small board car will start but yellow lamp will stay on.
  17. The Following 3 Users Say Thank You to Babanovski For This Useful Post:
    LKEY (9th June, 2021), motohacker84 (18th March, 2020), vladanr (23rd May, 2019)
