Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    Top Poster georgegt's Avatar
    Romania
    Have someone pcb and schematic for this ?
  2. #47
    Apr 2012
    American Texas
    I've bought chinese BDM100 in gray aluminium box. It hasn't worked yet properly. I've replaced all transistors - green led lights now. I've started to change 93C46 dump. Probably I've tried all dumps from DK forum. Only two of them "work" - Windows XP sees device but 555Pro gives error:
    Interface communication error (E13)
    MPC version error (E06): 0x00000000
    Part number error (E05): 0x00000000
    Power error or communicationerror (E14)
    I attach these two dumps which "work"
    Do you have any idea what to do?
  3. #48
    im having the same issue with 2 different china BDM100 i ordered new resistors now what else can i try till they get here ?
    thank you
  4. #49
    Mar 2011
    i have the same problem with my bdm100. I already replaced all 3 transistors, but still dont work. windows dont recognize it at all. when in start dimsport software it say that there is no interface found. what is problem?
  5. #50
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Hello DK m8s.I think I once gave files from my BDM 100 on DK-a,incl.ept,bin fajl for 93c and HC11E1.If you do not find, tomorrow I give the whole project,work 100%.See pics in first post,...All the best to all.
  6. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    poxxxy (25th October, 2016)
  7. #51
    Mar 2011
    Quote Originally Posted by MOBILTRONIC View Post
    can u please post whole project?
    regards
  8. #52
    GB
    Default h
    here project.
  9. The Following 20 Users Say Thank You to hbalazs For This Useful Post:
    Adi202 (2nd June, 2022), agabna (18th May, 2014), autorisp (23rd May, 2016), bajad (16th March, 2021), carcode (21st May, 2021), clickerfux (21st May, 2020), cocutanu (29th January, 2014), d.zio (14th March, 2016), danielif (23rd June, 2020), dudujorge (25th October, 2015), ioanrokos (1st June, 2016), javivi (14th April, 2014), Jerry15 (19th November, 2016), jokerdiag (11th September, 2020), lisodemul (6th July, 2022), Markc78 (22nd December, 2019), neksus (19th March, 2019), poxxxy (25th October, 2016), scoot (22nd May, 2014), SRACHIDS (9th September, 2014)
  10. #53
    hi guys
    i have a bdm 100 v2.11 i put the power lead in no green light will this help me out above posts
  11. #54
    Fec001's Avatar
    I changed all transistors but program still doesnt recognize: Firmware Revision V.01 and SN: 0258.
    Any hints?
  12. #55
    Aug 2019
    anyone has bdm100 windows7 driver please
  13. #56
    Jul 2021
    I have the same problem, BDM100 not recognize by windows, i tried XP, Seven and Ten, have you found a solution ?
  14. #57
    Feb 2018
    I just received my BDM100 without software so I tried multiple drivers/applications and came up with this:
    I can read/write alltogether (they call it single file) however I would like to read/write to the individual ROM's but the buttons are disabled
    any suggestions?
  15. #58
    Oct 2021
    Reviving an old post but many still buy and try to use these BDM 100 labelled units , there is an inherent fault as the voltage drop is too great to properly power up the ECU through the unit.
    best fix is to remove pin1 from adaptor if soldering to board on ECM ( pin 1 on board is 12v supply )
    power is to be applied to ECM through pin 5 and pin 18 ( 12v power and ign 12v ) and -ve through pin 1 on the ECU itself ( in the larger ECU connector ) - use a good 12.50 v power supply or even car battery to power the ECM .
    using this method recognition rate and reading has been 100% , even on ECU's that have previously had problems.
  16. The Following User Says Thank You to Mikky058 For This Useful Post:
    R1rf23 (25th November, 2023)
  17. #59
    Jan 2022
    France south west cost
    +1 that Mikky058 : I had the same issue with a chinese BDM 100 programmer. My solution is to plug an 12,5v external power to the ECU's pin 1 pin 5 and pin 18. all worked fine!!
