### guide for setting up non usals for dm800 ### - Page 2
Results 16 to 30 of 45
  1. #16
    Apr 2011
    I have followed guide to the point of storing satellites 28.2 and 19.
    I have all the channels on 28.2 but how do I get the dish to move to 19 so I can do a scan
  2. #17
    May 2011
    Default Motorized Dish Setup Question
    Any best guode to setup DM800HD with motorized dish with C+KU LNB with a Diseqc switch.
    When I setup, with LNB1 with C-band with Diseqc 1.2 and A/A command. LNB2 with KU band universal with Diseqc 1.2 and A/B command. USAL=No.
    Sometimes dish does not move to the stored location, while on DM500 has no issue.
    Thank you
  3. #18
    i have dm800 hd pvr , and problum is freezing all channels and showing aswell 76A error aswell
  4. #19
    May 2011
    Angry DM800 Positione settings
    All,
    I am new in this forum. I have a DM800 with Domica 8.0. I tried several images and I have the same problem when I try to configure the positioner. My dish is not oriented as it need to be (South 0.0). When I search for a satellite and I found it. I store it on a dedicated position (1). After exit, the motor move to another place. Are the satellites positions are automatically calculated as I have filled the longitude and latitude of my position?
    Could someone help please?
    PS: I tried several images and the problem is the same.
    Thanks in advance.
  5. #20
    May 2011
    Thumbs up DM800 Positione settings
    All,
    sorry, I had to reply first to access to the pdf file explaining how to set up satellites positions manually. I discovered what was wrong in my configuration. In fact, to set up manually satellites, I had to set Usual to No. That's it. I suppose, if we set Usual to yes, the OS calculate automatically the satellites positions using longitude and latitude we have stored within satellite configuration.
    Thanks to whom posted the procedure.
  6. #21
    Help Please
    I can't set up more than one sat!
    I'm using Blackhole image, latest, have tried others, got a moteck v boxII to move the motor.
    I go through the following procedure to set up and scan a satellite:-
    1. Go into Tuner Configuration and choose a satellite,
    Astra 28.2E,
    then I choose all other settings within that menu,
    LNB 1, Universal LNB, 13V, DiseqC mode 1.2, Use Usals for this sat = NO, stored position = 1.
    2. Go into Positioner Setup,
    Choose Tune, (Red Button) and then select Astra 28.2E, set a frequency that I know I can get (BBC) then press OK.
    3. Go into Positioner Movement and find Astra 28.2E - all OK so far.
    3. Go into Auto Scan, and scan in channels.
    Right up to this point it works OK, I now have all channels available scanned in for 28.2E.
    I now try to repeat the process for the next satellite,
    1. I choose Thor or any other satellite.
    choose all other settings as in no. 1. above, except I use stored position = 2.
    Choose Tune, (Red Button) and then try to move off Astra 28.2E, but cannot, it won't let me scroll through the satellites to any other, it just is stuck on Astra 28.2E?
    Any ideas guys
  7. #22
    Aug 2011
    I presume this is a similar to the set-up for 500HD
  8. #23
    Jun 2011
    HI GUYS,
    Is this manual applicable for DM800HD se? I'm affraid that I do not have options like "use USALS for this satellite" and stored position?
  9. #24
    Aug 2011
    Would also like to know i this works on a 800 se.
    Thx
  10. #25
    Aug 2011
    Default Guide to install satellite
    Please, can you explain how I do to install a single satellite ( Intelsat 11, 43.1W ). on my DM 800?
  11. #26
    Sep 2011
    Hi i live in New York and I just bought dreambox 800hd but i am having hard time to set it up. I am using a dish and LNB from direct tv. I was wondering if this dish and lnb works works with the dreambox. if not which one do i need to buy to make it work. also im interested in a guide lines to get this working. please help me and thank you very much.
  12. #27
    Quote Originally Posted by bobo06 View Post
    Help Please
    Astra 28.2E,
    Any ideas guys
    I have the same problem can anyone help ?
  13. #28
    Hi I just got my Dreambox and used this guide to set it up. Works really well with my dumb stab motor. Used the settings as described and it worked perfectly.
    I have one issue that seems to be problematic. The box will not store all the satellites after I scan them so on the satellites green button I only seem to be able to access the default sat list.
    I am sure I will get to the bottom of it but it is causing me some grief. The channels that it has found for the non default satellites are not even displayed in the all channels red button menu??
    Thanks any way for a great guide it got me started anyway.
    Allan D
  14. #29
    Apr 2011
    Quote Originally Posted by gazzacun View Post
    same problem here any ideas guys?
  15. #30
    Apr 2011
    Quote Originally Posted by scooby1905 View Post
    Help Please
    Astra 28.2E,
    Any ideas guys
    Same here any ideas guys please
