Page 1 of 16 12345611 ... LastLast
Results 1 to 15 of 231
    Jul 2010
    Default Suzuki Ignis Blaupunkt code needed
    Would you help me with an unlock code?
    My serial numbers are:
    BF 8 631 340 325 -3
    C 40312707 369
    4 9559905 7643063510 7
    39101-86G10
    e1 022903
    Thanks in advance!
    danyguit2000's Avatar
    Dec 2009
    Earth
    Code is 3607
    Jul 2010
    Oh man!
    You are fantastic! It works!!!
    Thank you!
    Jul 2010
    Default CD-s Blaupunkt k?d kellene.
    Szia! Nekem is elhal?lozott az akkum az Ignisemben csereut?n a r?di?m k?dot k?r de sajnos nincs.
    Kivettem a f?szk?ből ?s a k?vetkező sz?mokat tal?ltam az oldal?n l?vő c?mk?n.
    Vonalk?d: 3 194340176430635103
    Alatta: 39101-86G10
    ID: 39101-86G1 e1 022903
    Valahogy ilyen elrendez?sben is.
    Malayzi?ban k?sz?lt ?s a bal oldalon van m?g egy BOSCH felirat is.
    Ha tudn?tok erre k?dot megk?sz?nn?m.
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by fekecssandor View Post
    Alatta: 39101-86G10
    A bit poinless telling you to Intoduce yourself mate ... but please post in English ...
    Code is .....5737....
    alexics's Avatar
    Jan 2010
    Kidderminster
    Quote Originally Posted by PremierD View Post
    I think he wants a code but I'm just guessing. He could be ordering fish and chips.
    Jul 2010
    Sorry, non in englis, very-very thank you opt.
    Bay-bay: Sanyi
    alexics's Avatar
    Jan 2010
    Kidderminster
    Alatta: 39101-86G10
    Hello! Also, the battery died on me Ignisemben csereut?n the radio asks for code but unfortunately it is not.
    Weyr and took the following numbers found on the side of the label.
    Bar code: 3 194340176430635103
    Underneath: 39101-86G10
    ID: 39101-86G1 e1 022 903
    Such arrangement is also something.
    Made in Malaysia and the left side there is a BOSCH subtitles as well.
    If you guys appreciate this code.
    Courtesy of Google translate translate.google.com
    Dec 2009
    Earth
    Code is 5737
    Jul 2010
    HI, I have suzuki ignis 1.5 2004. Today I had to replace a battery. Since I've lost my complete blue book (car radio with the code and service manual) I tried to do that with jumper cables to avoid loosing voltage but failed. Now the radio is asking for code.
    The problem is I cannot find any of the codes guys here are listing. I only have VIN under the front windshield
    Could you please help me locate these codes
    Dean
  11. #11
    Jul 2010
    Quote Originally Posted by deankavicki View Post
    Dean
    OK, figured it out. Needed to pull out the radio (using 4 long nails as recomended in some other post)
    The barcode serial is:
    SI3C4S20608BC
    I'm not sure at the second position if it is a letter 'I' or digit '1'
    Hope someone would be able to help me now
    Dean
  12. #12
    Jul 2010
    I have Suzuki Ignis (2007).
    Barcode: 6 9970519 7643063510 5
    SN: SI5AVS20700ICD
    Thanks alot!
  13. #13
    Apr 2010
    Quote Originally Posted by a3s View Post
    SN: SI5AVS20700ICD
    Thanks alot!
    your code : 7021
  14. #14
    Jul 2010
    SI3C4S20608BC
    Dean
    Just realized I'm missing one letter in the barcode serial
    Here is the correct one: SI3C4S20608BCD
  15. #15
    Jul 2010
    Sorry but the code above seems to be completely wrong from the wrong sticker. Here are the correct ones this time from the bosch sticker 4 9546740 7643063510 0 39101 - 86G10 ID 39101-86G1 e1 (in a square) 022903 FD481 (oriented vertically) on the right side of the label
