REally Thanks!
Is there any catalog to know wich key is good for write and wich is for program from UCH?
Like exaple I have a Suzuki key it has 4c TEXAS. Zedbull sad Just write to 4c or Tx1. But somebody sad that If I have a blank 4c than I can't just write for that I need a Tx1.
I want to buy a new suzuki key from china with blank 4c texas chip!
So Can I just press Write button or not?
Thanks for helping!
There isnt such a thing as a "blank" original 4C because original 4C's have a factory fixed manufacturer ID.
The TPX1 is in esscence a fully writable, aftermarket 4C and is able to be programmed with the Identification of a standard 4C transponder.
So IF I buy one of these:
Suzuki Transponder Key
And I copy the original key, can I just write to car or I has to program it with code from UCH!?
I know that tx1 is vaiable to write it on but that aftermarket key has 4c chip in it! So what????
Yes you would have to program it using a diagnostic tool and the pin from the UCH because your car wouldn't recognise the ID of the new 4C chip.
A TPX1 main use is when you are cloning an already working key or generating from an immo dump because unlike an original Texas 4C you can also change the ID code of a TPX1.
You can give the TPX1 the same ID and encryption code as the original and it will then start the car with no further programming needed.
does the clone come with the "Renault System 1" function found under "Extended functions" ?
Here's the crazy thing I have a genuine Zed bull without the EEprom package and its ?450 to upgrade. Very simular to a new clone unit.
So do I upgrade or get a clone unit as a spare? I know which makes more sence. Unless I can upgrade through a dealer for less out of the UK?
pitake (18th April, 2018)
Thanks for that.
The "Renault System 1" proceedure is a bit involved.
After preparing a working transponder you have to load a file into the UCH / BIC unit to record the remote.
Any chance of some letting me have a copy of the file to play with?
Thanks in advance.
Well I think that all experts have lost interest in this post .
Any ways I wanted to tell you that now Zed Bull is $400 shipping included in most of chinese sellers.
Would that be because is something better coming???
i see it here also for 350usd .
cj
joe06 (26th March, 2018)
friends bought another zed bull china seems that this came true,
now I need a lot of tips shared here, and also post, my s experience hehehhe
