Raptor181 (6th May, 2018)
"I believe the DS chip is a SECURE memory chip with the serial hard coded into the chip. So you aren't going to get the contents of the chip or be able to change the serial number of it!
You either need to use the original chip and get update files from a Chinese seller to get the tokens or buy another unit."
Hi all and Fallen
Now, i will help anybody bec i solved to read all info from one zb.
You will repair all mini zb and big zb for this files. I repaired my 3pces zb
Enjoy all members !!! & Happy New Year 2018 !!!
Regards, G
Alfa GTV (31st December, 2017), amper (1st January, 2018), ancient (4th January, 2018), andrzejopel13 (1st January, 2018), anonbeat (8th June, 2019), Arcos (16th December, 2022), asensi (17th March, 2022), baba59190 (8th January, 2018), Bishop c4 (31st December, 2017), Carkeysa (31st December, 2017), datapage (2nd January, 2018), dorofteius (2nd January, 2018), droidwayne65 (31st December, 2017), ecufix (Yesterday), Fallen (21st January, 2018), Faraday (31st December, 2017), H2Deetoo (7th October, 2022), hbalazs (28th January, 2021), hoangtu (21st January, 2018), ickromwerk (3rd March, 2019), jankesp (2nd January, 2019), joe06 (23rd March, 2018), just4upal (31st December, 2017), kuzmanov (31st December, 2017), laki23 (28th October, 2018), mikajna (17th January, 2018), mikroel (31st December, 2017), miloudmess (2nd February, 2019), mista1234 (27th June, 2019), okm (2nd March, 2023), pablobonome (7th March, 2018), PANFUTY (1st February, 2018), PeterOBD (22nd October, 2018), rocris (3rd July, 2018), seregka (5th September, 2018), slavisac (27th May, 2018), solitaire (31st December, 2017), Stelaras26 (22nd January, 2018), stoyanov (2nd January, 2018), tehnosoftex (1st January, 2018), Tomate (1st December, 2019), vomit (4th February, 2018)
hI
hAPPY NEW yEAR !!!
Is this the main code for zedbull atmega code on zed bull clone ?
Best Regards
JOSÉ
auto techniek (12th January, 2018), triak88 (4th January, 2018)
Hello friend. Tank you for the zb files. I tried to revive my zed bull mini clone (0 token) but no luck now the display is just green and nothing, it is dead. I tried writing whit USBASP and put the fuses just in the picture but nothing. I get every time error at byte 8.
Any ideas ? thank you.
I also tried another programmers and I got as the same result.
After I tried with ELNEC Beeprog programmer and success all of them.
That is why that i uploaded my elnec project file.
If you send me your faulty programmer, then i will repairing it.
Write me a pm.
Regards, G
hi, this is the secret board zed bull scematic
Thank you. I did not see the lock bit, Tommorow I will try once more whit USBASP if no lock I will ask a friend ho has ELNEC and if no luck whit him than I send it to you, Thank you.
Hello friend. Witch one is the ok file the 260kb or 261kb ? thank you.
this is your project opening fuse elnec .
thank
Regards, G[/QUOTE]
can uploaded again zed bull clone v05.02 please?
