Page 3 of 40 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 586
  1. #31
    Sep 2011
    italy (mafia land)
    Quote Originally Posted by smoggy View Post
    the password is correct
    make sure you are typing it in correctly
    is your keyboard a qwerty type
    could try a plug in keyboard
    With microsoft usb keyboard, same problem... incorrect password
    what can possible?
    some days ago i have try to close the cmos jumper ...but im not lucky
  2. #32
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by Lordformat View Post
    what can possible?
    jumper doesn't work on these
    providing you have posted your tag in the correct case and inputting the password in correct case the password should work
    Eiz9gyr6FKkq73sw upper case in red
  3. #33
    Top Poster sca.net's Avatar
    Exclamation DELL INSPIRON 2650 - BIOS PASSWORD
    Hello Friends, please can you help with password to DELL INSPIRON 2650 Laptop?
    I can acces to OS, but i can not modify parameters in bios, it ask me for password, i buy it with this problem.
    I'm not sure about what code you need, so here i public 2 pics from TAG 9H9ZJ0J and ID from this laptop.
    Thanks in advance for your help.
  4. #34
    smoggy's Avatar
    Apr 2009
    UK North East
    sca.net
    password 1z9jy6uv
  5. #35
    Default Incorrect Pass
    sca.net
    password 1z9jy6uv
    Hello my friend, Thanks for your help, but it says password incorrect.
    Maybe the problem to generate the correct pass is the before last char "O" or "0" in Tag, i think is zero... Or what can i do?
    Hope you can help me to know the Master bios password from this laptop.
    Here the Service Number in a cap.
    Thanks again.
  6. #36
    smoggy's Avatar
    Apr 2009
    UK North East
    sca.net
    it looks to me a zero
    the one I gave was for tag ending -595B
    if its -D35B then gunz0dmp (5th is a Zero)
    if its -2A7B then password would be rMLB0D15oACay4io (5th is a zero 9th and last are o for orange) also note the the case changes
    make sure you type them in the correct case
  7. #37
    Default ....
    sca.net
    Hello smoggy...
    Sorry to be a pain, but it still says incorrect password and i get "System Disabled [15328]" at 3th try.
    I try in different ways with those passwords you gave me but no succes.
    I dont find any of -595B,-D35B,-2A7B endings in any place in this laptop... The Only Service TAG endings i find is "ZJ0J" from "9H9ZJ0J". And Express Service Code is: 206-357-401-63.
    I've disassemble it before but didn't find the battery and also found no reset pin. what a problem i have....
    Any suggestions?
    Thanks.
  8. #38
    smoggy's Avatar
    Apr 2009
    UK North East
    the service tags are 11 characters and generally end in one of those three numbers although it doesn't always show them.
    only other thing I can suggest is to try a plug in qwerty type keyboard just in case one of the keys is not working correctly or your keyboard isn't set up as english qwerty
  9. #39
    Sep 2011
    italy (mafia land)
    Nothing my friend, i have try with Caps lock for E FK ,
    incorrect password
    the service tag is correct
  10. #40
    smoggy's Avatar
    Apr 2009
    UK North East
    incorrect password
    for tag 6697ZN1-2A7B password is Eiz9gyr6FKkq73sw
    I can only give you what the calculator calculates
  11. #41
    Hello
    Can you help me
    I need a password bios for my Latitude E5400
    Service Tag : jwd5d4 - 2a7b
    Express Service Code : 433-158-673-15
    Thank you for your help
  12. #42
    smoggy's Avatar
    Apr 2009
    UK North East
    jeanmi33
    you are a character short in your tag, also post it in the correct case as tags and passwords are case sensitive
  13. #43
    ooops
    this is Service Tag: JWD5D4J
  14. #44
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by jeanmi33 View Post
    ooops
    password HYOc125gi26a7wgj (note first 3 are upper case and 3rd is O for Orange)
  15. #45
    thanks you so much ,now is working
