Page 11 of 40 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 587
  1. #151
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by cheeko View Post
    Thank's for the fast reply, tried it but it says invalid passsword
    I calculated it with a suffix of -595B if you can see any different then post it
    it is also for a qwerty type keyboard
    it is the password for getting into BIOS not Admin password
  2. #152
    Quote Originally Posted by smoggy View Post
    really appreciate the help smoggy but i dont know where to look for this 595b.There is no other numbers after the service tag just the express service code. cheers
  3. #153
    smoggy's Avatar
    Apr 2009
    UK North East
    if there is no suffix then its generally -595B that works (or nothing else works)
    do you get an error code if you input the wrong password 3 times
  4. #154
    just restarts after entering wrong code 3 times.
    i just tried -595B and -D35B myself and got the password but none work. stumped now.
  5. #155
    smoggy's Avatar
    Apr 2009
    UK North East
    only other 2 suffixes are -A95B and -2A7B (this one will give 16 digit password in upper and lower case)
    but as I said if 595B doesn't work your generally out of luck.
    it could be one of the second generation suffix's which at present can only be done by Dell or paid service website
  6. #156
    Thank's for the time spent m8 , its a new ish m5030 ill try dell again. cheers
  7. #157
    Jun 2012
    Default I need Password
    Been looking Need help
    Dell Latitude E6410
    Bios Revision A05
    got it on my own
  8. #158
    Jun 2012
    Hi, I hope you can still help. My password stopped working.
    My message says "this computer system, #5LB0MF1-595B, is protected by a ...
    Type in system or administrator password
    I've my password for the last 2 days and it wont work. I've used the same password for years and it worked b4 I went on vacation last week. I have done nothing or made any changes and dont understand why its not taking my password.
  9. #159
    Quote Originally Posted by otazluver View Post
    try this 5kado8uo if 4th is a zero or this phggvd9e if 4th is o for oscar
  10. #160
    Jun 2012
    Default Thank You!!!
    Password worked!!!
  11. #161
    Jun 2012
    I have a Dell Inspiron 1501
    Service tag HJSH5C1 no suffix
    It asks for a drive password The s/n from the drive label is
    WX21A70P8413
    Also in setup it asks for a password and after 3 tries I get
    System Disabled [07934]
    Thanks in advance
  12. #162
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by ober0n View Post
    WX21A70P8413
    Thanks in advance
    can't promise anything but try these
    nqau8fax
    wudhsqu
    blpjen
    cpckig
    rknwagq
  13. #163
    Jun 2012
    wudhsqu worked for the bios. But no luck on the hard drive password. I do thank you for trying.
  14. #164
    Jul 2012
    Default Dell Latitude e6410
    Same problem here #1QCPWN1-2A7B
    ANY Help would be appreciated, thanks
  15. #165
    Quote Originally Posted by Talazon View Post
    Try this MC19ebcnOPFNrsVk ninth is capital o for oscar.
