Hi I am new owner of peugeot dijagnostics. Can someone with more expiriance say is there somthing that DiagBox activated with profile 2FFFFFFF can't do but PP2000 22.14 can.
Is there a way to reset ABS/ESR ECU from DiagBox v5.18?
Cheers
Work perfect with PSA XS like pp2000 and lexia.
Good point - I was not specific on car and ABS model.
Peugeot 307 2.0 16v (RFN engine).
Motor management is MM6LP
ABS ECU is Bosch with ESP. I do not have it with me right now, but in ABS ECU model is version 5.7
DiagBox is reporting as fault that ABS ECU is not recognized, then works a bit, in the end it is not reporting any fault.
I have tried to set make and model of ABS ECU through DiagBox, but I could not.
Thus - my idea to reset it, with hope of it working properly.
It is not that I have major problem, as ABS light is not ON most of the time. Occasionaly it pops up, and after few minutes it dissappears.
In conclusion - it can be 'software feature' of DiagBox, but it can also be sign that something is not right with ABS ECU.
Thanks for fast responses
I did not understand with google translator
tried to clean the abs sensors
regards
Hi Xilophene,
Problem I have is that DiagBox is not recognizing ABS/ESP ECU. Also through one of DiagBox menu's I cannot set the model and make for it.
So it is either DiagBox 'feature' or something is not right with ABS/ESP ECU. First one is not a problem, second one might be.
Cheers
hi kantarion
passes through a different way or try with old software PP2000 !?
best regards
Keygen Release.exe doesn't start in WinXP, is there some working version available?
hello why when i use diagbox for do peugeot 207 it read good vin and not found ecu and the sw diagbox go on pp2000 and woking good ?
please i nee you help if some know or meet this
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
There is plenty bugs in Diagbox, configuration failures, freezed modules, eved up to 5.34 BSI update in 508 causeing absolute BSI wipe - game over. Plenty downloading operations faulty or not processing in Diagbox but running very well in PPS. If you dont have 2009 - 2011 cars beter stay with pp2000.
where can I diagbox software
