A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
mang5087 (10th January, 2014)
Please make file for
pas:123456
Thanks again for that info.I have 2008a install and data I think and have a gen RERR0010-51 disc as well as the 9 DVDR0001-51 discs that are working with a friends 2008a SIS that was mine with other programs that he needed,so am trying to start again rather than swap all our programs around.I am not sure if I have enough to make it work and what my discs are as in are they data or just updates.I know the login for the other setup but it does not work on this setup. col
Does the admin userID/pass work to make a user id with your SIS? And are you clicking on the SIS user admin and inputing the user/pass there? If it don't work on yours can you try your friends to try to fix it. Personaly I would upgrade to STW 2009b and start over, I know it's a lot of work but you have done more work to get 2008a going.
If you need more help just ask.
please.....
americandiesel
123456
thanks in advance
Hi again RS none of the ID,s or PW,s work with this setup the other one works fine but I did not install it as we bought pc with programs on it and working some time ago and all I know is that it is 2008a and works with jan 09 discs which it asks for when you select a particular model.If I change to 2009b or c I will need all the 11 discs I think for it.My download speed is not great and a bit costly at present so was trying to use what I had on hand.Regards again col
