Page 2 of 42 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 627
Thread: 2010 Cat SIS
  1. #16
    DK Veteran Poptest's Avatar
    Sep 2010
    Quote Originally Posted by joshplianfield View Post
    you must change your default internet browser to internet explorer as Cat SIS does not work in Chrome.
    here is STW install this first SIS options only
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Cat RERR (install second)
    links are here if they no longer work pm me
    http://www.digital-kaos.co.uk/forums...21/#post728367
    disk 1, cover heavy trucks, only disk I have or even needed, please do not ask me for the other as I don't have and didn't need (you need virtual cd 9 or similar to mount the vc4 image to a virtual drive)
    virtual cd9 w/crack, download and run, then open the disk 1 files and mount the VC4 file into the virtual drive that VCD9 created
    Do a search for SIS user files.
    If you need a SIS key please PM me.
    Would you know if this SIS version runs on Windows 7 64 bit?
    Thanks.
  2. #17
    Quote Originally Posted by Poptest View Post
    Thanks.
    not sure, most of use use windows xp (I think), all programs work great on XP home and pro.
  3. #18
    Top Poster niltonj59's Avatar
    Hello everybody I have et2009c kg (SULTAN), recently I installed the SIS 2010, the first network installation all worked, I put the license key and it worked normally. Just that something strange is happening every time I enter the SIS program asks me to put the license key again. The license should not be permanent? Could someone help me?
  4. #19
    Newbie hornet600's Avatar
    Default sis
    nd true, me e' succeeding also to me, after me is shrewed that start sis me exits all bloccato.lo rievvio aspect a po' and it goes all ok.
  5. #20
    May 2009
    is it possible for someone to upload information about only one engine?
    i only need cat 3304 engine so i don't want to download GBs of data with my slow net speed.
    Pls help.
  6. #21
    Hopelandic
    josh: the RER link you gave is not match with the sis installer links above, any help anyone?
  7. #22
    DK Veteran RSwire's Avatar
    your girlfriends house
    Quote Originally Posted by saratdusta View Post
    The RER files are in this thread http://www.digital-kaos.co.uk/forums...light=cat+rerr
    post # 5 The one in this thread is not right. Rember to thank the posters. Hope this helps.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  8. #23
    Quote Originally Posted by fw1374 View Post
    Pls help.
    Sorry your going to have to download all of it, you can't pick and choose what you want out of it. It's all or none.
  9. #24
    May 2009
    Quote Originally Posted by RSwire View Post
    owww
    thnx for the answer anyway.
  10. #25
    Hopelandic
    ah thanks for the advice, im already got the right links..
  11. #26
    Top Poster Strykerforce's Avatar
    Pls help.
    Can't do m8. If you need only this engine model, You can order the Service Manual for particular engine model. If you want to know the Media number, just give me the Engine Serial number.
    Cheers
  12. #27
    Default sis 2010a
    hi i have sis 2010A AND WHEN I TRY TO OPEN ITS ASK ABOUT LICENSE KEY ...MY CODE IS :
    SS 2437 FDF9 4810 568E 91B9 5EEC
    PLEASE HELP
  13. #28
    Hopelandic
    now, i need sis 2009b dvd data disks for dvd#6, 7, 8, and 9..
    do you guys have any?
  14. #29
    DK Veteran sattv1244's Avatar
    who have ET2010B KG SIS2010AKG can PM me
  15. #30
    Oct 2010
    alguen que me ayude con este codigo de licencia sis 2010
    SS 5004 BC59 1053 8086 C41B C991
    ayudenme con la clave de licencia por favor de antemano gracias
