Do a search for a member name VioletGirl, a few of their posts have full SIS data disk downloads on multiple file sharing links.
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
is a full vertion? or only for engine?
mm i have the 9 dvd, but how install all dvd to see all menu??
You don't "install" them. You run them like a cd. What I did was make a vitual cd of the disk (I only needed on-highway) and when asked by SIS I inserted the vcd in the vcd drive. It works for me just great. With all the disks it is the same thing just choose what vcd you need (sis will tell you what cd is needed) and insert in vcd drive. Hope this helps.
ok ok, i have the 9 data dvd in 9 virtual drive, but my problem is, whem i puss Select Equipment Model, the list is only for engine, i dont see the all.. like the attached..
per exemple,, no any information about HKT, A8F, J8B, BAA, RTB, 4PS, 01X, 2KR, RBB, B1N, AWR, M1G, JLP, 63X, 7ZF, and more and more...
Try this, go to the section of sis in your picture, click on the type of equiptment, a screen on the right will open, click on your prefix.(or enter prefix in the spot for it in the main page) it will take you the the main page. In the right column there is "basic search" click on that( it will tell you what cd you need), type what you are looking for and that should do it. Let me know.
the some problem.. Sorry, but there are no equipment configurations that match the product information you have entered.
I cant see any equipment, only Engine.. all information is for engine.., i think the rpoblem is a configuration, i try to install another vertion of the Install Disk RERR0010... i cant see the problem,,
I wonder if your problem is your licence key? Or .xml file?
There are different levels with different keys. If the .xml file don't include the right "stuff" it will limit your use. Lets try your licence first what is your code I have the KG for full serv dealer. And if that don.t work we will try a new .xml file.
I can not think, i use another "user" template and now it works fine, many thanks, I'm half crazy, jajjaa thank you very much...
hello need cd motor garden cd6 please no found
HELP ME
SS 0419 6F8E F280 FF6D 847C DE04
SIS CAT 03/2010
