Page 1 of 37 12345611 ... LastLast
Results 1 to 15 of 627
Thread: 2010 Cat SIS
Hybrid View
    May 2010
    Default 2010 Cat SIS
    you must change your default internet browser to internet explorer as Cat SIS does not work in Chrome.
    here is STW install this first SIS options only
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Cat RERR (install second)
    links are here if they no longer work pm me
    http://www.digital-kaos.co.uk/forums...21/#post728367
    disk 1, cover heavy trucks, only disk I have or even needed, please do not ask me for the other as I don't have and didn't need (you need virtual cd 9 or similar to mount the vc4 image to a virtual drive)
    virtual cd9 w/crack, download and run, then open the disk 1 files and mount the VC4 file into the virtual drive that VCD9 created
    http://rapidshare.com/files/16526657...cld.Serial.rar
    Do a search for SIS user files.
    If you need a SIS key please PM me.
  2. The Following User Says Thank You to joshplianfield For This Useful Post:
    morran (1st March, 2018)
  3. #2
    DK Veteran RSwire's Avatar
    Jun 2010
    your girlfriends house
    Just what I was looking for my friend. Thanks a million.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    May 2010
    Share on!!!!!!!
    Mar 2010
    Hi, thanks for these links...do you have those two discs DVDA9020-XX flash files? if so, could you please also share them? I have a 3126B ECM that won't communicate and I need to re-flash it.
  6. #5
    Jun 2010
    Do a search, there are flash files here .
  7. #6
    Mar 2010
    Oh OK I will, thanks...ahmm any hints?
  8. #7
    Jun 2010
    Quote Originally Posted by mawjed View Post
    http://www.digital-kaos.co.uk/forums...ht=caterpillar try this it is the 2009 flash cd.
  9. #8
    May 2010
    like RSwire said they are on here, I personally do not have them.
  10. #9
    Newbie dewi's Avatar
    Sep 2010
    Hi.......
    Do you have SIS 2010A Keygen...???
  11. #10
    DK Veteran mondao's Avatar
    Quote Originally Posted by dewi View Post
    Hi.......
    http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
  12. #11
    DK Veteran Poptest's Avatar
    Sep 2010
    Quote Originally Posted by joshplianfield View Post
    Would you know if this SIS version runs on Windows 7 64 bit?
    Thanks.
  13. #12
    May 2010
    Quote Originally Posted by Poptest View Post
    Thanks.
    not sure, most of use use windows xp (I think), all programs work great on XP home and pro.
  14. #13
    Oct 2012
    Hi Mr. Poptest, I run SIS and ET on different Windows platforms, right now I am running on Windows 7 Ultimate 32 bit without a problem, Win 7 64 bit crashed or the SIS program would freeze almost every time I tried, ET would not work on Win 7 64 bit.. I have SIS 09 though..
  15. #14
    Top Poster niltonj59's Avatar
    May 2010
    Hello everybody I have et2009c kg (SULTAN), recently I installed the SIS 2010, the first network installation all worked, I put the license key and it worked normally. Just that something strange is happening every time I enter the SIS program asks me to put the license key again. The license should not be permanent? Could someone help me?
  16. #15
    Newbie hornet600's Avatar
    May 2010
    Default sis
    nd true, me e' succeeding also to me, after me is shrewed that start sis me exits all bloccato.lo rievvio aspect a po' and it goes all ok.
