UPA USB and 68HCP11A1 as 68HC11A8 old - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    As the thread is bumped up,
    UPA USB can't read all 8P.xx ECU's IN CIRCUIT without lifting the pins as known but to lift pin on PLCC chip is not that easy, or cutting the lines. Another alternative for UPA is to make it works stronger and then working well on those ECU's without lifting pins needed.
  2. The Following User Says Thank You to Zmann For This Useful Post:
    autocargo (26th March, 2013)
  3. #17
    autocargo's Avatar
    Quote Originally Posted by Zmann View Post
    Can you tell us more? What mods we have to do? It's good to know all that as it speeds up the job.
  4. #18
    Apr 2012
    Wonderland
    it possible to read it without desoldier mcu or lift pins from board, but you have to apply current to ecu
    ProTuner since 1999
  5. #19
    Apr 2012
    Wonderland
    tested injectmds solution and it work
    ProTuner since 1999
  6. #20
    Cepe Verde
    with chip soldered to ro board and lifting the pins mentioned above it works 100%. thanks a lot
