Hi new to this forum. So do I have to have special wires to plug it into the engine???
Hi Guys,
I have an odd one for you. My spare IDS VCM was "borrowed" from the back door of a dealer in the USA. I went to pay for updates and it will not allow me too. It says contact Rotunda blah blah. I called them and they told me it was registered to so and so Ford in America.
On the IDS screen it says that the subscription has run out and asks for a code, when you click no it just shuts down. I know the VCM is 100% original and I use daily on LR/JAG.
My question is does anyone have a crack/patch to unlock the software.
Am running IDS V68.
LD
NO, BUT check with other members first TRY flashing the head to something else and see if that kills it, eg another model
My friend if you VCM is built on USA you need update the VCM because the version 68 have a code for lock all the VCM not suscribes on the Database, for unlock you need only register and update but the cost is $500 dolar at year.
Good luck
P.D. you can do that on this page http://www.motorcraftservice.com/vdi...il_renewal.asp
It does exactly the same no matter what version is installed, the VCM is old. But due to it being nicked from dealer Motorcraft will not allow me to pay for any updates on it.
I have tried flashing both ways, connects like normal but when you connect to vehicle says the software is expired.
It is my back up VCM which is why I wont spend any money on it.
LD
pm member diagnose64 ask him
My friend try to reinstall the IDS software but change the date of the PC and the BIOS for the date of release the version of you try install, before of try to install unistall the already installed version and clean the registry.
I think you should try to take a completley new installation (also clear registry entries) and install the last software which works on your IDS diagnostic head!
Install the software, check if it's working, then install fakedate.exe (look for it in net) the you shouldn't have a problem with Date expiration.
I'sure in near future there will bi a possibility to work with your VCM also on newer Software Revisions
enjoy and have Fun
Tom
have you got a good copy of fake date you can upload?
I do not like downloading from google.
I have tried fresh instalations and makes no difference.
the VCM has to be de-registered by the previous owner before you can register it and pay for updates in the US system. $500 per year EVERY YEAR including the years not updated before you had it.
OR
de registered in the US and registered as owned in europe at 125 euros per month per dealership regardless of however many VCM's you have.
OR
there was someone up t'north reflashing them and using the chinese software (ebay), but you can never update them with a later version of IDS or they timeout again.
mines clne running at versionb 67 and it works fine...the calibration file sre nbo tlonger on thew disk it goe sout to server for them so i open internet once im at the flash screen and reflash and sut it down cause iot does go out an dlook for updates and it WILL update itslef! but i wont let it....but i have clone working fine at verions 67 or i use older cal files from disk v65...68 scares me a bit but well see....it wont cause anythign but a reinstall or older software so ill let ya know
the calibration files are on the discs I get.
along with updated files for the VCM and VMM
