It was Stolen
Sent from my SM-G900F using Tapatalk
Attached is Display file st93c66
Once again thanks for all your help.
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
My Friend "shooting"
You made my weekend, and my customer. Thank you very much!!!!!!!
It works.
You also must have a great weekend
Hi. BID Display was replaced on the car, and now is shown DISPLAY SAFE. I read eeprom from original radio Blaupunkt CD30MP3 95640 and eeprom from new (second hand) bid display 93c56.
I have Opcom clone, but if there is a possibility, can someone made these files paired?
I will be very grateful if someone write also full procedure to get it working. Regards!
BID and CD30MP3.rar
@shooting ? :P
Tawe (28th March, 2017)
Put this dump in radio.
Display is currently set with BC function off. If you want to use BC function, need to change index to 10. Fuel sensor is on linear voltage at the moment, if you have the older Astra H then may need to change it to linear resistance in display (read IPC in car to see which fuel sensor it has).
Most things are possible.......
Your dump should have BC now switched on. This is assuming that the car has voltage type fuel sender. If you find that fuel use is not accurate for the car, tell me and it can be changed to resistance type sender easy enough.
I didn't realise Opcom can't even change these simple settings.
