Page 40 of 130 FirstFirst ... 3035363738394041424344455090 ... LastLast
Results 586 to 600 of 1943
  1. #586
    bank's Avatar
    Feb 2017
    Ukraine
    Default opel DISPLAY SAFE
    For unregistering radio you need unregistered display.
    Or you need unregistered radio to pair with registered display using code from display, then unregister
  2. #587
    May 2011
    Quote Originally Posted by bank View Post
    and i don't have any of them....
  3. #588
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by tryplex92 View Post
    So you need programmer to read dump from radio eeprom, shooting will make unregistered dump, you'll write it in eeprom then paid radio with display using code from display.
  4. #589
    May 2011
    next days i will post radio dump here for unregistering(now i can't read it cheap carprog clone)
  5. #590
    bank's Avatar
    Feb 2017
    Ukraine
    Carprog, as I know, can do it
  6. #591
    May 2011
    that means i'm unlucky
  7. #592
    shooting's Avatar
    WALES
    Incorrect information, display does not need to be unregistered, just untethered by radio
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  8. #593
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by shooting View Post
    Why incorrect?
    If you have registered radio and unregistered display, you can unregister radio using code from radio
  9. #594
    shooting's Avatar
    WALES
    Post your radio's dump when you get it then we can unregister it, then simple pair and all ok
    wbr
  10. The Following 4 Users Say Thank You to shooting For This Useful Post:
    Albert G (18th February, 2018), bogege (18th February, 2018), REZON (18th February, 2018), tryplex92 (19th February, 2018)
  11. #595
    May 2011
    wbr
    I sorted out radio and display i found one application to read security code for cd30mp3...now i need to found 1 app to can read security codes from VDO Siemens GID displays or if someone can help me i will post tomorrow bin file!
  12. #596
    shooting's Avatar
    WALES
    Send it to me in PM and I will give you your pin
    wbr
  13. The Following User Says Thank You to shooting For This Useful Post:
    tryplex92 (25th February, 2018)
  14. #597
    bank's Avatar
    Feb 2017
    Ukraine
    op-com 08-2010 rus can do it. Just doble click on the blue area and calc will be opened.
    By the way, pin stores in DIS without any coding, in clear view. But need to be swapped for Siemens
  15. The Following User Says Thank You to bank For This Useful Post:
  16. #598
    shooting's Avatar
    WALES
    This link is for one version only, if they use it on another tool they could brick it....
    There are many versions of 08-2010 from China and Europe and they are not compatible
    V4, V5, V6 China, EU-CL V5, EU-CL V6 and even enhanced versions of each....
    To be safe you must only use the software that came with the cable.. or buy a real tool
    wbr
  17. #599
    bank's Avatar
    Feb 2017
    Ukraine
    wbr
    Proposed version of software is only for calculating pin from dump.
    It contain "hidden" calculator inside
  18. #600
    shooting's Avatar
    WALES
    Pictures would be safer
    wbr
