thanks Bank, thanks shooting if you can help me about that I will really appreciate that,,
regards
regards
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
germanml (3rd October, 2018)
Hello friends (shooting and Bank) your both are the best, thanks a lot, problem solved
regards
I there if anyone can help please?
I have a Corsa C with Blaukpunt CD30 radio and display, the radio does nothing and there aren't any messages like radio or display safe. Could this be a corrupted firmware?
I attached the images if anyone can help please?
If they aren't for the same car could you please set the images for pairing in car?
Thank You and best regards
gameiruz (4th October, 2018)
They have the same code?
[QUOTE = gameiruz; 3388105] Те имат същия код? [/ QUOTE]
the code is the same! 8509
Yes i pressed the central switch...
Does anyone have the pinout to turn this on on bench? Please?
Check the power to the radio,there are pins on the radio !
Check for fuse under the quard-lock connector, also check fuse in box near the engine (F12, F35 for Corsa C)
Fuses
[spoiler]
Fuse 1 - 7.5 Amp - Central Control Unit
Fuse 2 - 7.5 Amp - Engine Control Unit
Fuse 3 - 7.5 Amp - Instruments, Information Display, Horn, Hazards, Immobilizer
Fuse 4 - 5 Amp - Numberplate Lamp
Fuse 5 - 20 Amp - Electric Window (left)
Fuse 6 - 10 Amp - Automatic Transmission
Fuse 7 - 30 Amp - Headlamp Wash System
Fuse 8 - 10 Amp - Starter
Fuse 9 - 20 Amp - Fuel Injection Systems, Fuel Pump, Stationary Heater
Fuse 10 - 10 Amp - Horn
Fuse 11 - 15 Amp - Central Control Unit
Fuse 12 - 20 Amp - Information Display, Infotainment System, Radio
Fuse 13 - 10 Amp - Vauxhall Alarm System
Fuse 14 - 7.5 Amp - Exterior Mirrors
Fuse 15 - 15 Amp - Windscreen Wash System
Fuse 16 - 5 Amp - Courtesy Lamp
Fuse 17 - 20 Amp - Central Control Unit
Fuse 18 - 20 Amp - Sun Roof
Fuse 19 - 5 Amp - Vauxhall Alarm System
Fuse 20 - 20 Amp - Electric Window (Right)
Fuse 21 -*Unknown - Please contact me if you have any information on this fuse
Fuse 22 - 5 Amp - Central Control Unit, Immobilizer
Fuse 23 - 20 Amp - Windscreen Wiper
Fuse 24 - 5 Amp - Infotainment System, Information Display, Courtesy Lamp, Instruments, EPS
Fuse 25 - 10 Amp - Brake Lamp
Fuse 26 - 20 Amp - Automatic Transmission, Fuel Injection Systems, Reverse Lamps, Cigarette Lighter
Fuse 27 - 15 Amp - Seat Heater (right)
Fuse 28 - 15 Amp - Seat Heater (left)
Fuse 29 - 20 Amp - Rear Window Wiper
Fuse 30 - 15 Amp - Engine Control Unit
Fuse 31 - 15 Amp - Air Conditioning System
Fuse 32 - 5 Amp - ABS, Easytronic, Automatic Transmission, Airbag
Fuse 33 [Petrol engine] - 15 Amp - Engine Control Unit
Fuse 33 [Diesel engine] - 7.5 Amp - Engine Control Unit
Fuse 34 - 30 Amp - Diesel Filter Heater
Fuse 35 - 5 Amp - Sunroof, Electric Windows, Radio
Fuse 36 - 10 Amp - Dipped Beam (left)
Fuse 37 - 10 Amp - Dipped Beam (right)
Fuse 38 - 5 Amp -*Tail Lamp*(left), Parking Lamp (left)
Fuse 39 - 5 Amp -*Tail Lamp*(right), Parking Lamp (right)
Fuse 40 -*Unknown - Please contact me if you have any information on this fuse
Fuse 41 - 15 Amp -*Fog Lamps
Fuse 42 - 10 Amp - Fog Tail Lamps
Fuse 43 - 10 Amp - Main Beam (left)
Fuse 44 - 10 Amp - Main Beam (right)
Fuse 45 - 30 Amp - Interior Fan
Fuse 46 - 20 Amp - Engine Control Unit
Fuse 47 - 30 Amp - Heated Rear Window
Fuse 48 - 30 Amp - Starter
Fuse 49 - 50 Amp - EPS
Fuse 50 - 40 Amp - ABS
Fuse 51 [Petrol engine] - 60 Amp - Easytronic
Fuse 52 [Petrol engine Z14XE, Z18XE without Air Conditioning] - 40 Amp -*Cooling Fan
Fuse 53 [Petrol engine] - 30 Amp - Air ConditioningCooling Fan
[/spoiler]
bogege (4th October, 2018), gameiruz (4th October, 2018), masterskay62 (4th October, 2018)
Thank you all for your help,
I manage to connect the TIS with another radio on bench and it works but have radio safe message 10m minutes with beep, i have the original dump of this radio and the TIS dump.
The radio is a delphi grundig unit with 24c32.
Is it possible to match these devices? I can't do it with opcom everything except fault codes are greyed out.
Thanks for any help.
gameiruz (5th October, 2018)
